Need help leveling a tm60 on a Tym TM25.
   / Need help leveling a tm60 on a Tym TM25. #1
old farmer man
TYM T25
Bought a tym t25 about a year ago from a dealer in TN near KY because I heard great things about them.
The TYM T25 turned out tobea great tractor but I'm having problems with the mower deck or may be the person who installed everything to do with it.
Long story short I need information on how to level the mower deck. I have the lift arms equal, level to each other but the deck is still not level.
I HAVE A WORK SHOP MANUAL but it does not go into the deck nor mower.
Can someone help?
   / Need help leveling a tm60 on a Tym TM25. #2
Check the TYM World site for a manual for the mower deck. TYM typically has the information for loaders, mower decks, and backhoes separate from the tractor manuals, as the accessories may be used with several different tractors. Or superseded by newer versions during the life of the tractor.
Here is the link to the manual for your TM60 mower deck. https://tym.world/media/uv1eh52p/tm60-mower-operator-s-manual-part-list_202301.pdf
Have it, did it, no help.
Thanks for input.
   / Need help leveling a tm60 on a Tym TM25. #4
All I can suggest is to check all the frame attachments against the manual, and while you’re there retorque the bolts.
   / Need help leveling a tm60 on a Tym TM25. #5
I have the same issue with an older T254 and mm60 mower. There's a nut on the j-hooks that I tightened and got it close. But is looking like I may need to engineer a solution as the new parts I bought didn't change anything.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
2018 CATERPILLAR 908M LOADER (A52706)
2018 CATERPILLAR...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
ALLISON TRANSMISSION (A55745)
ALLISON...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
