Need help John Deere power steering
   / Need help John Deere power steering #1
chevgmc12
ford 601
I have a john deere 1020 that has a loader that I like to put power steering on. I bought the priority valve on ebay and I can buy the steering column on line. looking on line on installing the power steering and can't tell if iI have the right pump on my tractor and also where to hook up the return line off the steering column, All pic on line don't show where the return line goes need help.....Thanks
   / Need help John Deere power steering #2
Power steering on JD utility tractors returned oil to trans case via a galley built into clutch housing. Pressure oil was supplied to power steering housing(key 4) via a pressure line from frt pump back to priority valve. Which hyd pump does your tractor have(.69/4 piston or 1.38 IN.3/8 piston)? I think your tractor probably has a 4 piston pump.
How do I tell if it痴 a 4 piston, and will a 4 piston work with power steering and a bucket. The md of the tractor is T4RIC. 086524T, can I tell by the md#and SN
   / Need help John Deere power steering #4
4 piston pump photo & 8 piston pump photo
   / Need help John Deere power steering #5
An open Center priority valve is going to be a total mess on a tractor with closed Center hydraulics .
Find an entire 20,40 or 40 series tractor and swap parts to make it a 100% factory system.
   / Need help John Deere power steering #6
To my knowledge JD didn't offer a priority valve for open center steering on 1020/2020,300 or 400 because it didn't require a priority valve because it was powered by it's own open center pump & remainder of hyd system was closed-center hyd's.
   / Need help John Deere power steering #7
That would be why I was telling the poster that an open center priority valve on a closed centre hydraulic system was not a good idea. I wonder why the adding of some aftermarket PS system that will cost more and not work as well as the factory system?
All that really needs to be done is to drop in a steering column from a power steering tractor . Connect the inlet to the HP hydraulics and drain the PS unit into the transmission case.
   / Need help John Deere power steering #8
One slight problem b&d is in your post #5 you stated ""open-center priority valve"" which doesn't exist for a JD 1020. The correct priority would be a good idea if OP installs a closed center steering valve similar to later model 1020's.
   / Need help John Deere power steering #9
Exactly , the 1020 is closed centre so why would an open centre priority valve be added. And why some aftermarket PS system when a PS column from a junked 20,30 or 40 series Dubuque or Mannheim Utility tractor will bolt on. No fuss, no muss and operate perfectly .
I hope the poster can get back to us and return that after market PS system.
   / Need help John Deere power steering #10
chevgmc12 never stated he was adding """an open center""" priority valve similar to photo but you did state that. Open center hyd such as early 1020 didn't need a priority valve because that system utilized 2 hyd pumps similar to tractors built today.
2005 KENWORTH T800 (A53843)
2005 KENWORTH T800...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
2008 Chevrolet Uplander (A51694)
2008 Chevrolet...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53473)
2016 RAM 5500...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
