Need Help John Deere L120
/ Need Help John Deere L120 #1
Seth1wa
Big lake, mn
John Deere l120
The shaft on gets really hot and then the pulley gets hot then the belt melts and starts to come apart. Starts good runs goods but keep going through belts. Please help. Just got done trying a new clutch didn't work. Did tune up new oil oil filter spark plugs air filter fuel filter.
/ Need Help John Deere L120 #2
Which shaft?
The more likely problem is belt tension, slipping on the pulley.
A little more details might help others help you.
/ Need Help John Deere L120 #3
I assume that you're talking about your mowing deck drive belt??? Sounds like a bad bearing in one of the spindles. Try to spin things by hand and see which one is tough to spin ---- that one would be the problem.
The heat starts in the shaft the pto clutch slips onto the the pulley starts to get hot on the pto clutch then the belt. When I first start the mower and let it run for a minute or two I can feel the bolt that holds the pto clutch on and it is very warm and this is on a new pto clutch also if I also if I touch the big nut that comes up through the flywheel that is hot as well.
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A64553)
2025 GIYI GY-PG72C...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
John Deere 2032R Tractor and Loader (A66285)
John Deere 2032R...
