Need help in removing 60" mower - NEWBIE
   / Need help in removing 60" mower - NEWBIE #1
Hellspawn
S.W. Illinois
2011 Kubota B2620
I got a B2620 last summer with the LA364 loader and added the 60" standard cut belly mower. I spent 2 hours this afternoon trying to get it off and got nowhere and now I am so frustrated I don't care if I ever see it again.
I need to take the blades off to be sharpened and to grease everything on the deck that needs it.
I got as far as taking the rear link 'L' pins out, but this is what else I don't understand.
1. It says turn the PTO to LOCK (there is only open and close)
2. slip the U-joint coupling to release (it doesn't move - it has a grease fitting but that's all).
I'm thinking I had no business getting this if I can't even figure out something which the dealer says is so simple.
Any help at all would be greatly appreciated.
   / Need help in removing 60" mower - NEWBIE #2
Do you have the manual for reference? The MMM on this model has a drive-over feature but I always do it manually. I raise the deck all the way up and rotate all the anti-scalp wheels so that it will roll out sideways. Once I have all of them rotated, I lower the deck until they make contact with the ground surface. The next thing I do is disengage the rear L pins. You'll notice there is a small cotter pin near the springs, which keeps the pins from falling out but also keeps you from backing them out if you don't remove them first. There is a slot in the bracket to hold the retracted L-pins once you remove the cotter pins. Next I lower the front linkage and remove the support brace that connects the front linkage to the hooks on the front of the deck. Lastly, you need to remove the PTO shaft. There is a collar right where it connects to the PTO. Slide this back and it should stay locked back. You can then slide it right off the PTO shaft. Lastly raise up the 3PT control to lift the rear linkage out of your way. Now you can roll it out sideways. Once you master that, you'll want a set of mower axles to make maintenance and storage a snap. Good luck!
   / Need help in removing 60" mower - NEWBIE #3
Evil's instructions are spot on, even for the BX series. I think what they mean by "turn the PTO to LOCK" is to ensure the PTO selector lever is set to the mid mount position. The PTO shaft shouldn't be able to turn on you while pulling the collar (slip the U-joint coupling to release) back towards the front of the tractor.
The mower axles that Evil referred to can be purchased at Mower Deck Axles,Carrera,Cayman,John Deere,Kubota. Highly recommend a set of these, my mower is stored on a set of these all winter long.
Yes I have the manual for it but your description makes a little more sense to me.
I get everything you say except the collar part I think; I see a U-joint at the back and right behind the mower gearbox. In the middle of the shaft there is a great fitting. Is this the collar? I tried quite a few times and it does not want to slide or move.
I know this is a bit ahead, but is there a suggested or recommended way to get to the blades to remove them? That deck seems a lot heavier than my prior JD 54c deck that I could lift and prop up.
Thanks!
I was thinking that it simply meant turn the OPEN-CLOSE knob to CLOSE to lock.
   / Need help in removing 60" mower - NEWBIE #6
If you are speaking about the knob between your legs on the right, that knob controls the speed of drop on the 3PH (3 point hitch).
   / Need help in removing 60" mower - NEWBIE #7
This is not your exact deck, but this is a representative collar you need to pull back to remove the PTO shaft.
oh ok, I was somehow thinking that the part in the middle was what would slide. That piece is going to be on the tractor end of the shaft, not the deck gearbox, correct?
That picture helps immensely as the manual doesn't seem to illustrate where it is!
I know what that one is, it was set to just barely open by the dealer and they said to leave it there.
   / Need help in removing 60" mower - NEWBIE #10
subcribed
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
