Need Help Identifying this John Deere.
/ Need Help Identifying this John Deere. #1
beendeere
Onalaska, Texas
1953 John Deere 40u
Acquired this tractor has no serial number data tag. Need to know year model and serial number range. Have engine serial number -720 76,if that helps. Want to order parts to restore. Pictures attached. Thanks, any help would be appreciated.
John Deere 039.jpgJohn Deere 040.jpgJohn Deere 041.jpgJohn Deere 042.jpgJohn Deere 043.jpgJohn Deere 044.jpgJohn Deere 045.jpgJohn Deere 046.jpgJohn Deere 047.jpg
/ Need Help Identifying this John Deere. #3
I think according to SN it's a model 40 Tricycle built in 1953
It could possibly be an M if JD built that many in the last yr but I think the SN's didn't overlap.
/ Need Help Identifying this John Deere. #4
I concur with TxJim - a Model 40 - we had the next model up the JD 420 on the farm. The model 50 had a flywheel on the left side.
/ Need Help Identifying this John Deere. #5
I agree it's a 40, but also it definitely is not a tricycle. The serial number suggests that it is, so I would guess it either Is a 40U that had an engine swap, or a 40t that had a front end swap. Either way, it looks like it is in pretty good shape. Should make a nice one to restore!
/ Need Help Identifying this John Deere. #6
40 Tricycle had the factory option of a wide frt axle. Here's proof straight from the parts catalog.
/ Need Help Identifying this John Deere. #7
The engine serial number didn't necessarily match the tractor serial number on the Dubuque built tractors, but they were recorded in the serial number register. You can contact the Two Cylinder club at Twocylinder.com and have them research your tractor. It costs, but may be the only way to tell what your tractor serial number was. Then you can apply to Deere for a replacement SN plate. It won't look like the original, but would be official.
On the other hand, if the motor has been changed, the only way to get the serial number range is to get a parts catalog and start narrowing it down based on production changes.
/ Need Help Identifying this John Deere. #8
It ZOOMED right over my head(poor reading comprehension) that the number listed wasn't the machine SN. Plus I should have realized it had too small of rear tires for it to be a 40T but I was homed in on the serial number.
Thank you everyone for the info on tractor ID. This narrows it down to a 1953 to 1955 John Deere 40U. I Think...
213141 (A64276)
213141 (A64276)
JMR TREE BOOM (A61572)
Iranch IRET13 Electric Tricycle (A64127)
Iranch IRET13...
2022 EZ-GO ELITE...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
