Rotary Cutter Need Help Identifying New to Me cutter
   / Need Help Identifying New to Me cutter #1
johnwllms309
Ga
1967 Ford 4000
Hello all,
I have only posted a few times and thanks to everyone that replied. I recently acquired a rotary cutter/ brush hog with no tags/ stickers or anything identifying the brand. So far I don't really need anything other than a maybe a gear box seal( after using it saw some oil on bottom of output shaft) and maybe blades later just want to know more about it.
I bought it at a dealer in Lithonia GA all they could tell me is it came from a county department which I can't remember the name.
Thanks
John
   / Need Help Identifying New to Me cutter #2
Looks well made, don't know the brand.
Check that the gearbox vent is working.
Buy some corn head grease, or NLGI grade 0 (zero) grease and you won't have to replace the seal.
More info click here
Thanks for the information I just want to prolong replacing the seal for little awhile at least until the wife gets over my recent "tool" acquisitions including this cutter.
   / Need Help Identifying New to Me cutter #4
Looks heavy duty.
Yeh it's a monster looks like 1/4" plate top not sure about the sides, some of the angle iron looks like 3/8" or larger, and the main angled supports look like 1/2" or larger. Found a vid on you tube with one exactly like it I am going to see if maybe he know's the brand.
I am new to tractors it has a pretty good bit of vibration especially at low RPM is this normal?
Are the blades generic enough just to match another brand?
Thanks
John
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2016 R and R Products 331 LP Reel Mower (A55851)
2016 R and R...
Utility Trailer (A52377)
Utility Trailer...
1999 VaXcavator VT500D T/A Towable Vacuum Trailer (A55851)
1999 VaXcavator...
