Need Help Identifying Kubota L3130 Hydraulic Line
   / Need Help Identifying Kubota L3130 Hydraulic Line #1
R-G
CT/NY
This line/fitting is leaking and i cant find my manual to see what line it is. Tractor (05) is a hydrostat so i believe its a tranny line? I dont know if its a flare fitting or an o ring, everything is tight. Im out in the middle of no where so i would like to replace the whole thing the next time im out there. Need to know what line it is, part number or any info that can help get it fixed. Thx in advance..................R-G
Well ive got the new part in hand and its just as its stated in the parts book, a pipe, no fittings came with it, no flared end on it. Is this supposed to be a compression fit? Pt# 130 in the pic is what im replacing.
Kubota_10238456_L3130DT%20GST%20HST_CLUTCH%20TRANSMISSION_HST%20REGULATOR%20PIPE%20COMPONENT%20PARTS%20HST%20TYPE_normal.gif
(2) 18.4-34 TRACTOR DUALS (A51244)
(2) 18.4-34...
10' Feed Bunk (A50515)
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2006 Reelmaster Toro 3100D Commercial Mower (A50322)
2006 Reelmaster...
