Need help identifying Ford 2000
   / Need help identifying Ford 2000 #1
Homestead Blue
Bronze Member
Cleveland, TN
1964 Ford 2000
Hey guys,
I recently inherited a Ford 2000 tractor that I'm going to get running to help me begin to homestead. I am having trouble identifying the tractor based off the serial numbers I'm seeing. I'm most interested in the year, and if it's gas or diesel. Any help you guys can give will be greatly appreciated!
   / Need help identifying Ford 2000 #2
I don't know why, but some pictures posted on this forum I cannot open.
I'm new here, so it may be how I attached it. Here are the numbers:
21201
♢51647♢
   / Need help identifying Ford 2000 #5
You could probably smell inside the fuel tank, but the spark plug check is the best method.
   / Need help identifying Ford 2000 #6
Spark plugs or else... look for an injector pump on the side of the engine block with fuel lines running to the injectors (diesel), as compared to seeing a carburetor sitting on top of an intake manifold (gas).
Thanks so much guys! It definitely has plugs, so I guess gas it is. Now I'd just like to narrow down the date. I found several sites like tractor data that show the codes, but it doesn't make sense based off the numbers I have. Does anyone know the difference between the top and bottom numbers?
   / Need help identifying Ford 2000 #8
Looks like a 1964 model based on the serial number. If you can, post a picture from the side that shows the whole tractor.
Scroll down to the thousand series:
Identifying Old Ford Tractors
   / Need help identifying Ford 2000 #9
The top number decodes the model number. The lower number is the serial number.
Count the number of spark plugs...I'm guessing it will have four, which makes it the earlier thousand series. The later thousand series had three cylinders and a more square shape (totally new design) hood etc. From the pic in your avatar it looks like the earlier series (still good machines BTW).
Here's a side view
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Toro (A56857)
Toro (A56857)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
