Need help from a member with a lathe
   / Need help from a member with a lathe #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
I am needing a member with a lathe willing to cut a hole in a schedule 80 PVC clean-out cap like the attached picture. All I need is the larger center hole cut for the rubber stopper, and it is important that the hole be centered and at the same angle as the rubber stopper taper (hence needing it done on a lathe). I am able to do the rest using a drill press. If you can assist please PM me.
   / Need help from a member with a lathe #2
i gota ask, what on earth are ya makin, looks like some sorta check valve maybe? i have a lathe here, 14 inch logan that would be plenty up to the task, a bit far away from you tho, hopefully someone closer will pop up
My son is a member if the IPLA and this is part of a high tech project that I'm making for him. Have any idea what the IPLA might be? /forums/images/graemlins/wink.gif
Thanks so much for the kind offers guys but Bob Skurka jumped all over my post and volunteered as soon as my request was posted on the board.
   / Need help from a member with a lathe #5
International Potato Launching Association /forums/images/graemlins/grin.gif
CTyler you guessed it.
The IPLA = International Potato Launching Association
This combustion launcher with a chamber/barrel ratio of .8:1 will hurl spuds at approximately 375 MPH when finished. This check valve will be used in conjunction with a brushless fan mounted within the combustion chamber for quick venting after every shot.
   / Need help from a member with a lathe #7
Be careful out there. We wouldn't want an epitaph reading "Death by Potato" . /forums/images/graemlins/grin.gif
   / Need help from a member with a lathe #8
If the Hawaiian shirt guy cannot get the job done for you. Send me a PM. My lathe is all cleaned up from the last project.
   / Need help from a member with a lathe #9
I've made a couple in the past /forums/images/graemlins/grin.gif
My SIL has couple, the favorite one uses compressed air. No idea have fast or far but it shoots a long way.
I remember being about 11-12 and taping tin soda cans together cutting the ends out of the top two. Stuff a tennis ball in and put lighter fluid in side hole in the bottom can. Worked fairly well. Didn't know what a potato gun was then.
   / Need help from a member with a lathe #10
How about grinding a regular wood bit to the proper angle??
Egon
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2009 SolarTech Silent Messenger II Solar Message B (A53117)
2009 SolarTech...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
