Need help-fluid levels-Montana T2334
   / Need help-fluid levels-Montana T2334 #1
CCoron
Waterboro, Maine
2008 Montana T2334
No Manual. Purchased used. Want to take care of her.:)
   / Need help-fluid levels-Montana T2334 #2
Not sure if this is what you need, but on my Montana 2740 (gear driven) there is a dipstick behind and below the seat to the right of the PTO shaft which shows the level of oil in the transmission/finals, which is also the hydraulic reservoir, since all gear cases on the 2740 all contain UTF. (universal tractor fluid) Check this level with loader on the ground, bucket curled back and 3PT arms in the down position. Oil level should be maintained between the upper and lower lines on the stick. Change filter and all oil periodically. I think Montana recommends after 200 hours. All filters for mine were available at NAPA and 5 gallon buckets of UTF at Costco if you don't have a Montana dealer nearby. Hope this helps.....Dan.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2015 FORD TRANSIT XLT (A52472)
2015 FORD TRANSIT...
