Need help-fluid levels-Montana T2334
   / Need help-fluid levels-Montana T2334 #1
CCoron
Waterboro, Maine
2008 Montana T2334
No Manual. Purchased used. Want to take care of her.:)
   / Need help-fluid levels-Montana T2334 #2
Not sure if this is what you need, but on my Montana 2740 (gear driven) there is a dipstick behind and below the seat to the right of the PTO shaft which shows the level of oil in the transmission/finals, which is also the hydraulic reservoir, since all gear cases on the 2740 all contain UTF. (universal tractor fluid) Check this level with loader on the ground, bucket curled back and 3PT arms in the down position. Oil level should be maintained between the upper and lower lines on the stick. Change filter and all oil periodically. I think Montana recommends after 200 hours. All filters for mine were available at NAPA and 5 gallon buckets of UTF at Costco if you don't have a Montana dealer nearby. Hope this helps.....Dan.
KUBOTA SVL-75 SKIDSTEER (A52472)
KUBOTA SVL-75...
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
HOME MADE SMOKER / FRYER TRAILER (A52472)
HOME MADE SMOKER /...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
