Need Help First Zero Turn Toro
/ Need Help First Zero Turn Toro #1
wallace8624
Beebe AR.
Toro 4200 Time Cutter
Need a little help, plastic pulley fell apart and the bearing went out so I replaced the pulley and now the z turn will not go forward or reverse the belt is on and the slides that you can move to roll the mower freely are in the correct area this is my first zero turn its a Toro 4200 Time Cutter I made the mistake of buying used because was not sure if I wanted to spend that much on a zero turn before I knew if I would like them or not, 1200 dollars guess ya get what ya pay for was hoping more the three times of mowing. Thanks for any help in this matter also the pulley is turning that comes down from the motor shaft.
/ Need Help First Zero Turn Toro #2
Welcome, and good luck. I'm sure you'll get some help before too long.
7002SFL (A61572)
7002SFL (A61572)
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
HD Quick Attach Grapple (A66408)
HD Quick Attach...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
