Need Help First Zero Turn Toro
   / Need Help First Zero Turn Toro #1
wallace8624
Beebe AR.
Toro 4200 Time Cutter
Need a little help, plastic pulley fell apart and the bearing went out so I replaced the pulley and now the z turn will not go forward or reverse the belt is on and the slides that you can move to roll the mower freely are in the correct area this is my first zero turn its a Toro 4200 Time Cutter I made the mistake of buying used because was not sure if I wanted to spend that much on a zero turn before I knew if I would like them or not, 1200 dollars guess ya get what ya pay for was hoping more the three times of mowing. Thanks for any help in this matter also the pulley is turning that comes down from the motor shaft.
   / Need Help First Zero Turn Toro #2
Welcome, and good luck. I'm sure you'll get some help before too long.
1996 International Water Truck with a Caterpillar Engine (A53472)
1996 International...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
