Need help finding switches - FACTORY switches
   / Need help finding switches - FACTORY switches
Got the Carling switches in yesterday. Haven't decided where I am going to mount them yet, but most likely in the dash, below the steering column I think. I'll post up pics when done. Still need to order the Kubota horn switch.
   / Need help finding switches - FACTORY switches #12
We're you able to get everything ordered and installed? I'd appreciate any pics if you have them as I am starting the same project.
Yep sure did. I didn't take any pics of the switches installed.....I made a mounting plate to mount under the plastic dash between your knees, just over top of the floor hump.... and you can't even see them when sitting on the tractor haha.
You doing switches or lights?
   / Need help finding switches - FACTORY switches #14
I am installing front and rear work lights that I want to switch separately. Originally I was going to use an illuminated rocker switch but after some thought I'm going to try to match the factory Kubota hazard light push button switch. At least that's the plan if I can find a match, so far no luck.
Ah ok. I ended up going with the Carling switches because I couldn't find the Kubota switch I wanted. Kubota told me they didn't make a light switch that is an exact match to the hazard switch, OTHER than the "FS" light switch.
   / Need help finding switches - FACTORY switches #16
What is the FS light switch?
Pic and part # on page 1. Switch has "FS" on it and a light symbol.
   / Need help finding switches - FACTORY switches #18
Do you have the dimensions if the three switch bezel that in the picture? I really like those switches and might mount more lights to use the third switch.
Well, I *finally* got around to installing the Kubota horn button and a Stebel air horn I've had for a long time. Figured I'd post pics and tie this thread off, sorry for the delay (I hate threads that just stop open ended)
I installed the horn over the battery, just behind the grille. Yep, it's LOUD.
   / Need help finding switches - FACTORY switches #20
Is that the Stebel Truck Horn ?
(I have one sitting up in the shop waiting to be installed ... if so, then yup ... they are LOUD :D)
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56138)
2012 FREIGHTLINER...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
