Need HELP finding post or poster !!!
/ Need HELP finding post or poster !!! #1
Casco1
New England
Kubota L series
When I first joined TBN I saw this thread for a personal lift. I kept two pics but didn't know how to save the thread at the time. I've spent probably ten hours over the last two weeks trying to find it with no success. Here are the photos I kept. I'd appreciate any help in finding this thread. Thank You, Guy /forums/images/graemlins/confused.gif
Second Pic
Thanks for the reply. I did a search on archdean posts found several pages but none had this particular thread. I'll keep trying it has to be out there somewhere. Thanks again
/ Need HELP finding post or poster !!! #5
Coupla comments:
Shortly after I joined, TBN went down (hope I didn't cause it) and any posts I'd made changed my name to "Poster" or something like that. It happened to a lot of folks, so it could be lost that way. The post is stil there, but without a name, maybe.
I found a new way to save pics of mods and stuff I want to save. I call it "man lift" for example, and then include the name of the poster in the filename, so I don't have to go through what you are doing (been there, got the t shirt).
Finally, while that man lift would be safer than standing in a bucket, I think it is still very dangerous. One sudden move on the down stick and you will not like the ride.
I would not risk putting anyone in my FEL like that. And I wouldn't trust very many people to hoist me up that way either.
Just my two cents.
ron
/ Need HELP finding post or poster !!! #6
</font><font color="blue" class="small">( Thanks for the reply. I did a search on archdean posts found several pages but none had this particular thread. I'll keep trying it has to be out there somewhere. Thanks again )</font>
Did you find any under archdean.
If so click archdeane on one of them; then when the page comes up click view all users post.
/ Need HELP finding post or poster !!! #7
Not the same personal lift but “Spencer” also made one. Might want to find his and see if the other poster jumped in.
MarkV
/ Need HELP finding post or poster !!! #8
</font><font color="blueclass=small">( Not the same personal lift but “Spencer” also made one. Might want to find his and see if the other poster jumped in.
MarkV
)</font>
Here is a link to all of Spencers post.
Shortened Long Link
MikePA: Please do not use the entire URL as the Link description. It makes the entire thread get very wide.
/ Need HELP finding post or poster !!! #9
</font><font color="blue" class="small">( Thanks for the reply. I did a search on archdean posts found several pages but none had this particular thread. I'll keep trying it <font color="red">has to be out there somewhere. </font> Thanks again )</font>
It is but not where we thought it was.
Here's onel ink:
http://community.webshots.com/slideshow?ID=196521110&key=AIadOn
LBrown59, I don't know how you did it, but your a better man than me!!! Thanks a lot, that is exactly what I was looking for.
<font color="blue"> RonR said, "I would not risk putting anyone in my FEL like that. And I wouldn't trust very many people to hoist me up that way either".
</font>
RonR, I understand your concern, but in this case, I've worked as a painter & licensed painter's rigger for over 20 years specializing in municipal bldgs, churches etc. and believe me I don't plan on being careless at this point in my life. I just think a rig like this would be handy at times for some jobs. Mine would be a little different as my loader has the ATI quick attach with factory fork setup. I think it would be nice to work off of a platform instead of a ladder. Thanks again for your help, Guy /forums/images/graemlins/grin.gif
/ Need HELP finding post or poster !!! #11
</font><font color="blue" class="small">( RonR, I understand your concern, but in this case, I've worked as a painter & licensed painter's rigger for over 20 years specializing in municipal bldgs, churches etc. and believe me I don't plan on being careless at this point in my life. I just think a rig like this would be handy at times for some jobs. /forums/images/graemlins/grin.gif )</font>
I think you should do a test of your loader before you spend the time building the lift. Last summer I was on a lift on a brand new tractor and we had to have someone sitting on the tractor to constantly "touch up" the curl on the bucket to keep the lift level. Most of our compact tractors will leak down or droop pretty quickly with pressure. To test, I'd fill the bucket with material and raise it up to about 8' with the bucket close to level. Let it set and time how long it takes for the loader to droop. If it holds, your lift is a good idea. If it droops, your lift will require two people and constant attention to work.
Good luck with your project.
/ Need HELP finding post or poster !!! #12
The other thing you could do is add an orifice to limit the flow of oil in the lines. That should reduce the speed at which the cylinders would go down.
Of course, the downside is that it would be SLOW as sin to lower it when you wanted to come down.
I guess you could insert a manual shut off in the lines, so that neither the curl nor loader would leak down. You still run the risk of a line rupturing (ok, it is remotely possible), but it would guard against leak down.
A manual stop on the cylinder ram would be another option. If you look at tractor shows or fairs, any FEL in the air will have a safety stop in place.
I am not recommending this, just making an observation.
ron
/ Need HELP finding post or poster !!! #13
<font color="blue">LBrown59,
1*I don't know how you did it,
2* but your a better man than me!!! Thanks a lot, that is exactly what I was looking for.] </font>
1* I checked my home here on this board and found links to it I had filed there.
I also checked my personal e-mail filing cabinet on CompuServe and founds links there too.
/ Need HELP finding post or poster !!! #14
Shortened Long Link
MikePA: <font color="blue"> Please do not use the entire URL as the Link description. </font> It makes the entire thread get very wide.
Mike I used the shortened link method originally but it didn't work when i read the thread and clicked on the link i kept getting an error message instead of the page coming up so i edited the post and used the other method which appeared to work ok and I didn't notice the thread being extra wide when i read the thread after doing the edit.
The thread being to wide didn't show up on my computer of course I wouldn't know or see how it appeared on other folks computers.
Sorry about the wide display problem.
PS
Perhaps I should have sent Casco1 a PM instead of posing it.
Sorry my bad call
/ Need HELP finding post or poster !!! #15
Where can you get one of those gutter cleaning attachments in the last picture??? /forums/images/graemlins/grin.gif
/ Need HELP finding post or poster !!! #16
</font><font color="blue" class="small">( The other thing you could do is add an orifice to limit the flow of oil in the lines. That should reduce the speed at which the cylinders would go down.
)</font>
Ron, your solutions all work, but they aren't completely safe and I don't think the manlift I rented last year was completely safe either. There's always some risk. If I was going to do this, I'd want something like the double piloted check valves many of us have on our toplinks/sidelinks from CCM. That is rock solid and is mounted in rigid piping. If a hose bursts, the cylinder holds rock steady. You have to apply pressure to one of the hoses to overcome the pilot pressure and then the cylinder will move at normal speed.
Of course, by the time you get something built with all the safety and functionality you need, you might as well go out and buy a used manlift for about $3k to $4k and be happy. /forums/images/graemlins/grin.gif
/ Need HELP finding post or poster !!! #17
Jin,
I would agree with you about them not being safe. I am ignorant about the double pilot check valves, but they sound like a good deal.
I have this FUN memory of my youth (probably age 6) when I overnighted at a buddy's farm. The next day, buddy's dad put us in the FEL bucket of (most likely) an Allis 40HP tractor and raised us up and down while driving around the shop area. He even curled the bucket forward, scaring the stuffing out of us at heigth! It was probably the first time I got hooked how much fun tractors could be.
However, looking back, that was SO UNSAFE. I would never do that with my kids or any other kids today. Guess we were oblivious back then.
ron
Winchester Sign Metal Decorative Sign (A64557)
Winchester Sign...
11in. Bucket w/ Teeth Excavator Attachment (A64194)
11in. Bucket w/...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
