Need help figuring out which Oil/Coolant to use - Please and Thank You
   / Need help figuring out which Oil/Coolant to use - Please and Thank You
First of all - What climate are you in? North Alaska, Hawaii?
Most oils mix fairly well.
But cold climates can do with a llighter weight oil for starting in the winter.
Not so with anti-freeze.
If the plans are to keep the tractor you might want check the antifreeze color. Or just plan on draining, flushing and replacing. In general if you mix green and orange antifreeze they can form a thick, jelly-like substance that can completely stop all coolant flow which can lead to overheating.
The color of the coolant is definitely green.
So I could just go for a green antifreeze and I should be good? I was planning to drain and flush but could I just put some green coolant in it, which is also the recommended 50/50 ?
   / Need help figuring out which Oil/Coolant to use - Please and Thank You #12
If you are going to sell the tractor I would just add some green coolant and be done with it. The new owner if he is a member of TBN is just going to go and change it all again anyways.
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
1952 Army Jeep M38 (A57453)
1952 Army Jeep M38...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
