bullockcm
I was in a similar situation last year and earlier this winter with a slightly smaller Kubota L4240 & R4 tires.  Same size rear tires and slightly smaller front(10-16.5).  I ended up going with the OFA EKO 8's on front and 9's on the rear.  Not a lot of use so far, no damage to my concrete although I do plan on throwing something down just in case and obviously they provide the traction I was looking for.  Clearance is an issue, my rear tires are in the 3rd widest position, this leaves roughly 2" clearance from the tire to the cab.  On the insides I replaced the shackles with regular cross chain end links which has been fine.  Front clearance is tight but seems to be fine so far.  I also couldn't fine a central NY retailer/distributor and purchased directly from Windy Ridge Co in NH as referenced by other TBN users.  It turns out Lisco II in Afton NY does business with Windy Ridge, my chains were shipped for free to Lisco II and he delivered them to me for free as well.  Great customer service from both places but if I needed anything "logging" related again including chains I would check with Lisco II first.  They can be found on the web but don't have a big web presence, if you would like their contact info let me know.
