Need help ASAP!
/ Need help ASAP! #1
wksinatl
Atlanta
case IH 485
I am replacing a broken lift arm fork (earlier post) on my Case IH 485.
There is a large stainless nut that screws on to the arm. The nut slides up inside of the fork and is threaded on the arm from the top lift.
My question is: does this nut get captured between pin "A" and bolt "B"? Or... does the nut rest against bolt "B" at the bottom and slides up to a "stop" inside the fork itself?
It will fit captured between the A and B but will NOT go past the bolt all the way the inside of the fork to the "stop".
This should have been a simple job and has driven me NUTZ. I should have paid more attention to how is was together.
HELP ME OUT GUYS!!!
/ Need help ASAP! #2
I'm looking at my parts book, and assume you're talking about the lift link that doesn't have the crank handle? The book doesn't show where the nut is captured. The owner's manual says that the lower arms should be level when the left link (the one you are working on) is one thread away from it's shortest length and the right link ( with the crank) has the groove in the shaft at the top of the yoke housing. Maybe you could position the nut in both positions and see if one way lines up correctly.
/ Need help ASAP!
geneP,
Yes it is the left side. I got an answer from a local tractor guy. It is captured betwen the bolt and the pin. Otherwise it would have about 3"-5" of up and down slop in it before it actually started to raise the lift arm.
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
2008 Rosenbaur Spartan Gladiator Pumper Fire Truck (A64556)
2008 Rosenbaur...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2013 Nissan Pathfinder 4X4 SUV (A64557)
2013 Nissan...
