Front-End Loader Need help adjusting FEL bucket on new Kioti!
   / Need help adjusting FEL bucket on new Kioti! #21
You know we like to burden all fellow members on TBN with these gnawing problems from time to time.
Wait til he finds out the fix is letting some air out of the tires on one side! :D
   / Need help adjusting FEL bucket on new Kioti! #22
I had my tractor and FEL for 3 years now and just checked it. It is out about 3/8 and I never knew it till now. Why did you have to do this to me? Now I'm going to think about it was very time I use it.
Right from the start I noticed my bucket's left side contacts a level floor a bit before the right side. That was 5 years/830 hours ago. I never measured it and it has not changed since, other than it is quite scarred up. Unless something looks out of alignment I'd leave it. But I understand others like to keep their machines in nicer (aesthetic) condition.
First off, thank you all for the input on this little dilemma of mine! It appears that a combination of every comment on here fixed the issue! Here is how it all broke down:
I moved my tractor around to a couple of different locations and the result was the same, one side was almost 1/2 inch high. I then started measuring a ton of different locations on the tractor to see where it might be off. What I did notice right away is that the frame mount for the loader on the high side was indeed a bit high, but not high enough. Per the suggestion of s219 I then loosened BOTH sides of the mount and put some pressure on the bucket, I then remeasured and the mounts were almost spot on! I torqued everything back up and guess what....still 3/8" off. Better, but now what? I then lifted the bucket up a couple of inches and started measuring across my bucket and did in fact start to "gain" in altitude about 3/4 of the way to the high side but I could only measure 1/8" difference. I then rechecked the air pressure and per the observation of EricTheOracle when I checked air pressure I wrote off the fact that the air pressure was within a few pounds. I guess these tractor tires are not like car tires. A pound or two does make a difference!!!:thumbsup: Once I got the air pressure perfect I was within 3/16" and that seemed to be acceptable for my "mild" case of OCD!
Many thanks to all of you for your input, and my apologies if my post caused a few of you to break out the tape measures for some quality OCD fact finding of your own!:laughing:
   / Need help adjusting FEL bucket on new Kioti! #24
generalbegg,
That is a nice tractor, now a little amnesia and you are good to go. Hope you get past this and just enjoy using your new machine.
2-Seat Wooden Rocking Bench (A55853)
2-Seat Wooden...
2003 Big Tex 10PI...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2022 CATERPILLAR 315GC EXCAVATOR (A52707)
2022 CATERPILLAR...
PALLET OF (2) COMPRESSORS (A55745)
PALLET OF (2)...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
