Need guidance please! Antifreeze leak Case 580B
   / Need guidance please! Antifreeze leak Case 580B #1
mwarning
I've got antifreeze leaking down the exhaust side of the block on my 580B diesel...only leaks about 1 drip per every 5 minutes...but it is definitely leaking from somewhere up by the exhaust manifold. I haven't run the tractor for 4 weeks now and it continues to leak; probably a couple quarts total now. I'm thinking head gasket, but before I tear into it I thought I would seek out some help.
Any suggestions?
   / Need guidance please! Antifreeze leak Case 580B #2
Theres a freeze plug in the back of the head I beleive - maybe check that, or try some stop leak as a temp fix. Any water in the oil? Does it stop once its running/heated up?
Thanks for the reply Carl!--- I found out today that mysterious green fluid running from the engine was diesel fuel! I had antifreeze stuck in my head and never gave it a second thought. After I cleaned the gunk off the engine I could see a slow leak around one of the fittings in the fuel line. Tightened that up and all it good.
Thanks again for your help!
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
Adams 8 Ton Weigh Hopper (A53472)
Adams 8 Ton Weigh...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
