need ford 1720 help on hydraulics
   / need ford 1720 help on hydraulics #1
cobumski
I recently bought a ford 1720 I see a hydraulic manifold under right side with three tubes connecting to the loader joy stick, i assume one is inlet and one oulet return from joystick, what is the third ? and also can someone tell me which one is which I want to add power beyond with flow through valve in series with outlet from from joystick. All comments appreciated.Thanks
Cobumski
   / need ford 1720 help on hydraulics #2
Id have to check, but on mine,(similar)the dealer used one port to tap off a hydraulics loop for my splitter , Since, I have "spliced' into it to run another valve, for the Hydraulic top Link and plow swing. As long as the fluid is looped through the valves, and the end of the loop was hooked into the return hydraulic block under the tractor.I will get some pics to show you which port he used,
Maybe you can can post some also.
Allan
   / need ford 1720 help on hydraulics #3
With 3 lines, one is the pressure inlet to the loader valve. One is the return to tank line from the loader valve. The other is the power beyond line from the loader valve. The loader valve is probably marked as to which is which. If not, you can surely find a 1720 manual on the internet somewhere and it should tell which line is actually which.
   / need ford 1720 help on hydraulics #4
HMM after I read this, I had you in mind Mad.
I knew you'd know what was what and how to word it.
Were you hinting that there are 1720 manuals online? Other than purchasing the hard copy? I haven't searched since last year. And as usual have procrastinated about buying the hard copy. LOL.
Thanks
Al
   / need ford 1720 help on hydraulics #5
Here is one of the links I have to where these reprint manal can be purchased. Some are not cheap, but they are better than nothing.
Repair Manuals to Purchase
If i go inseries with power beyong with open spool valve will that work? or in series with loader valve return?
   / need ford 1720 help on hydraulics #7
Always in series with the power beyond. If you go in series with the return to tank line you will have basically nothing since tank fluid is neutral pressure and comes from the work ports not from the pump. BTW, your tractor has an open center system.
I have posted the plumbing instructions for aux valves here on TBN dozens of times. It's simple and easy to follow. Do a search for Rear Remotes and my user name and you will find them.
Good Luck.
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
UNUSED FUTURE LASER LEVEL W/ TRIPOD (A51243)
UNUSED FUTURE...
