Need FlexPin Help
   / Need FlexPin Help #1
J0be269
Bronze Member
Carrollton, Georgia
Kubota B2620
I tried searching, but so far my efforts have not been fruitful. I have some Fabco series 23 shanks, teeth and flexpins. The flex pins are the two pieces of metal joined by a thick neoprene center piece. I cannot for the life of me get these things to go in the holes when the teeth are on the shanks.
Can anyone please give me a tip of how you did it....
   / Need FlexPin Help #2
Have you tried to grind a bevel on each side of the pin on one end?
Or
Maybe grip the pin toward one end with a pair of Vise Grips and "Squeeze" the Neoprene together while driving the pin.
   / Need FlexPin Help #3
I squeezed them with vicegrips ,slightly offset from center, and then pounded them in with a 2 lb hammer.
Worked for me.
Good luck!
   / Need FlexPin Help
I was able to finally bash one in last night. I guess I had just figured there was abetter way than using a BFH. I can see no other way though so I'm going to stick with that method....I finally found a picture of an installation tool for them last night, which was just a piece of metal to drive the pins with if your hammer would'nt fit between the teeth
AGT Air Compressor (A50123)
AGT Air Compressor...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53473)
GALAXY - SET OF...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2010 VANGUARD 53x102 DRY VAN (A53426)
2010 VANGUARD...
