Need FEL cable replacement help ML4900
   / Need FEL cable replacement help ML4900 #1
Digger11
Montana 4940c
Hello,
I have a 2006 4940c tractor with a 4900 loader. The plastic end of the cable broke.I can't figure out how to get the joystick control apart to replace the cable.The cable goes in from the bottom, and there appears to be an allen bolt holding the pivot piece in from the side. Can anyone explain how to get the male piece into the new cable end? Thanks:confused:
   / Need FEL cable replacement help ML4900 #2
You need to unbolt the joy stick. then there is a 3rd pivot(no control, just balance) and you need to undo the other one too. Once all 3 are loose, they slide up and then you can remove or replace which ever one u need. I just did mine on my 2844r
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
LOT NUMBER 51 (A53084)
SKID STEER HYDRAULIC TREE PULLER (A52472)
SKID STEER...
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
