Need FEL cable replacement help ML4900
   / Need FEL cable replacement help ML4900 #1
Digger11
Montana 4940c
Hello,
I have a 2006 4940c tractor with a 4900 loader. The plastic end of the cable broke.I can't figure out how to get the joystick control apart to replace the cable.The cable goes in from the bottom, and there appears to be an allen bolt holding the pivot piece in from the side. Can anyone explain how to get the male piece into the new cable end? Thanks:confused:
   / Need FEL cable replacement help ML4900 #2
You need to unbolt the joy stick. then there is a 3rd pivot(no control, just balance) and you need to undo the other one too. Once all 3 are loose, they slide up and then you can remove or replace which ever one u need. I just did mine on my 2844r
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
44511 (A51692)
44511 (A51692)
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2020 KUBOTA RTV...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
