Need electrical advice (service wire)
   / Need electrical advice (service wire) #1
Western
Super Member
Wise county Texas
Kioti DK 35 now
I need to run wire from my meter pole to my house. I have 2 al wires that are 1/2" diameter or maybe 2/0. I have 200 amp service, not sure if the box in the house is 200 amp or not, its a repoed mobile home I bought.
The run from pole to inside box is approximately 70'.
I know undersized wire would be a no-no, the wire I have is bigger than the co-op used to the meter, but its free so i was hoping to use it. Also was wondering if I should go with like sized wire for the ground or maybe I can go smaller like a 1/0 wire. I like the cheaper way but safty is perimount.
Thanks
   / Need electrical advice (service wire) #2
If safety is paramount then hire an electrician to provide professional advice. Bad things can happen if you get it wrong! The couple of dollars that it would cost is nothing over the time you'll use the service.
Mike
   / Need electrical advice (service wire) #3
Two wires? You need at least three, probably four since mobiles usually have a separate ground and neutral run from the service pole. You also need a professional electrician.
   / Need electrical advice (service wire) #5
You really need to know the size of the wire you are looking at. If you cannot find anything, anywhere on it, toss it. Guessing on wire is a big no-no.
Since it's only 70 feet, you'll be money ahead by just buying new. Home Depot and Lowes are actually the cheapest on the price of wire that I've been able to find. My Electric Supply houses are more. Their service is better and they have everything in stock, but they are not competitive on their prices.
Aluminum service wire for a Moble Home is fairly cheap. Only a couple bucks a foot if I remeber, and I think it's two lines of 4/0 for your hot leads, one line of 2/0 for neutral and I think a copper line for your ground. I can't remember for sure about the ground wire as I put a ground at the meter pole and another at the breaker box with a ground at each location. I like lots of ground rods.
You can buy a 200 breaker box with breakers for around $200. GE makes a good one that you will always be able to find breakers for. Some of those older Moble homes and even houses have breakers that are just about impossible to find breakers for anymore. Might as well go with new and do it right.
With aluminum wire, be sure to use an anti oxidant at your connections. Aluminum wire has a bad habbit of working itself loose over time without the anti oxidant. It's a black goop that you just put on the exposed part of the wire before you tighten it down. With it, you shouldn't have to re-tighten your terminals. Without it, you will.
Even though the wire is usually rated for direct burial, conduit is always a good idea. Espeicaly if there is any rock in your soil. With such a short run, it's cheap insurance to never have to go back and redo it.
This is pretty basic and there's no real need to hire an electrician. The guy with the license probably wouldn't even bother with it, he'll just send his junior helper out to take care of you and charge you full price for basic information and a job that doesn't requre any specialized skills.
Eddie
   / Need electrical advice (service wire) #6
I have 4 O from meter to 200A box about 30 feet away
   / Need electrical advice (service wire) #9
200 amp residential service would be 4/0 AL or 2/0 copper. Ground wire at meter would be #6 to two ground rods. It is typical that the wires the power company brings to the service are smaller than the wires after the meter. From the meter to the first disconnect, you need three wires, two hots and one nuetral. From the first disconnect to the mobile home panel, you need four wires, two hots, one nuetral, one ground (typically 3-4/0, 1-1/0).
Unfortunatly, there are so many variations in local codes, and so many interpretations of the National Electric Code, it is almost impossible to make a list of all requirements you must meet. Electricians can be found on craig's list or thru services like service magic to handle a job like this. Just make sure they are licensed and insured, a quick online check at your state's website will reveal this information.
Thanks for the replys,
I have an electrician, he is on a cruise and I was supposed to have it buried when he got back. He's a family member so I will do the work I just didn't think about the wire prior to thier leaving.
Lowes and Home Depot don't sell Al wire, copper will run around $750 for just the wire. I did find a chart that said 4/0 for main "hot" in 200 amp AL. The box in the house IS 200 amp and requires the 4 wires as someone posted.
With the proper wire this would be easy, alot easier than wiring the house anyway.
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2011 INTERNATIONAL MA035 ROUSTABOUT TRUCK (A52472)
2011 INTERNATIONAL...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2010 Honda CR-V Multipurpose Vehicle (A51694)
2010 Honda CR-V...
