nunyabinis
Do you have any pics of your improvements on the interior of your smoker?
195* is that for internal temperature of you smoker or the internal temp. of the meat?
The only improvement to the inside is the metal heat baffle between the firebox and the smoke chamber. I cut a piece of aluminum flashing to fit the curvature of the smoke chamber and bent the top corners in toward the firebox so that it holds a two inch gap between the firebox and the smoke chamber to allow the heat and smoke to go up the left side of the smoke chamber but it blocks the radiant heat from the firebox. It sits between the firebox and the meat grate and sticks up a couple inches higher than the meat grate so that the meat grate actually holds it verticle.
The 195 degrees is the internal temperature of the meat. Once it hits 195* it has "given up", the collagen has broken down completely and the bones will pull out clean using two fingers.
I usually keep the cooking temperture between 275 and 300 degrees. That way it only takes about 8 to 10 hours to cook a large Boston Butt. I've tried keeping the cooking temp at around 225 degrees but it just takes too dag nab long to cook. Sometimes 24 hours. I'm too old for that.
I use lump charcoal and throw in small chunks of Hickory wood that I cut off the back forty for smoke. You want to make sure that you keep the fire hot enough to produce WHITE smoke from whatever wood you're using for smoke. If the smoke has a yellowish tint the fire isn't hot enough and it will impart a bitter taste.
If you've never tasted Maurice's Original Gourmet BBQ Sauce , I recommend that you order a bottle and try it. IMHO it's the best sauce for pork BBQ I've ever tasted....... and I've tasted a LOT of BBQ sauces. It really augments the flavor of BBQ pork. It's a mustard base sauce with apple cider vinegar in it. It'll be a nice change for you Yankees out there.
Welcome to Maurice's Gourmet BBQ
If you like pepper and vinegar sauce, you may want to try Jack's Old South. His is almost as good as my custom made sauce.
Jack's Old South BBQ :: Welcome to the best in BBQ!
South Carolina is the Home of Barbeque and has four different sauce "regions":
By the way, when I have LOTS of folks to feed, I pull out the Big Gun:
Sorry for the long post..... don't get me started about BBQ!!!
