Need detailed specs on 914A mower parts
   / Need detailed specs on 914A mower parts #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Does anyone have a shop manual that lists the actual dimensions on the parts, i.e. the spindle diameter? I have a very loose fitting drive pulley on one of my spindles on a 60" 914A mower and am trying to determine if the spindle is worn or if it is the pulley itself (hoping for that!). A quick check with a caliper I measured .747" diameter on the spindle. The inside diameter of the pulley hole measures .752" on the bottom and .761" on the top, suggesting wear from the wobble that has been occurring. I'm hoping its just the pulley that needs replacing.
Thanks for any info you can provide.
Brad
   / Need detailed specs on 914A mower parts #2
You know you need a new pulley, so go ahead and replace that. When you fit it on you should be able to get a sense of how it fits. Most pulleys that I have dealt with on mowers are softer than the shaft.
   / Need detailed specs on 914A mower parts #3
The spindles and pulleys on a 914 are all interchangable. Trade pulleys with another spindle and the answer will be obvious.
I guess I should have mentioned that I pulled the spindle/pulley last fall when putting the deck away for the winter and it is packed all the way in the back of my shed and I can't get to it right now. Was thinking of ordering a few things on line and was just trying to find out if I needed to order both parts.
UNUSED FUTURE HYD 16" AUGER (A51248)
UNUSED FUTURE HYD...
2008 Felling Step Deck Low Boy, 42', 82,500 GVWR (A52384)
2008 Felling Step...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
UNUSED RAYTREE RMVB78-78" VIBRATING BUCKET (A51248)
UNUSED RAYTREE...
(INOP) KUBOTA ZD326 ZERO TURN LAWN MOWER (A51247)
(INOP) KUBOTA...
