Need detailed specs on 914A mower parts
   / Need detailed specs on 914A mower parts #1
SacandagaBrad
Platinum Member
Southern Adirondacks, NY
TC24D
Does anyone have a shop manual that lists the actual dimensions on the parts, i.e. the spindle diameter? I have a very loose fitting drive pulley on one of my spindles on a 60" 914A mower and am trying to determine if the spindle is worn or if it is the pulley itself (hoping for that!). A quick check with a caliper I measured .747" diameter on the spindle. The inside diameter of the pulley hole measures .752" on the bottom and .761" on the top, suggesting wear from the wobble that has been occurring. I'm hoping its just the pulley that needs replacing.
Thanks for any info you can provide.
Brad
   / Need detailed specs on 914A mower parts #2
You know you need a new pulley, so go ahead and replace that. When you fit it on you should be able to get a sense of how it fits. Most pulleys that I have dealt with on mowers are softer than the shaft.
   / Need detailed specs on 914A mower parts #3
The spindles and pulleys on a 914 are all interchangable. Trade pulleys with another spindle and the answer will be obvious.
I guess I should have mentioned that I pulled the spindle/pulley last fall when putting the deck away for the winter and it is packed all the way in the back of my shed and I can't get to it right now. Was thinking of ordering a few things on line and was just trying to find out if I needed to order both parts.
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2022 RHINO X1808 LOT NUMBER 65 (A53084)
2022 RHINO X1808...
2015 DODGE RAM...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
