Need conversion info for Kubota 7200 Tractor
   / Need conversion info for Kubota 7200 Tractor #1
Hummer70
Kubota 7200 Ford 3000
Under a cover on top of the drive train there is a filter marked HYDRAULIC FILTER FILSTER HST HH660 36030 and I would like to find out if Fram makes this filter under their name. I was able to find out there was a Fram oil filter 3593A for the engine and Mobil Corporation told me the ideal engine oil was Mobil Delvac 10W-30 Extreme and I have installed new oil filter and the Delvac.
I went to seven auto supply places and they could not even find the above oil and finally I stopped at Advance Auto Parts in Aiken, SC and they said they could have it for me by 0900 the following morning so I ordered three gallons and picked it up the next morning and three filters from Wally World.
Can anyone tell me how to convert a Kubota number to a Fram? Thanks much.
   / Need conversion info for Kubota 7200 Tractor #2
You may be able to cross to Baldwin or Fleetguard / Cummins, but I doubt you will find anything from Fram.
The Baldwin or Cummins filters are quality filters, but will likely be a similar price as an oem Kubota filter.
I personally use oem hydraulic and transmission filters on my equipment.
   / Need conversion info for Kubota 7200 Tractor #3
RJCorazza, I used to work at Aberdeen PG.
Thanks for info guys.
I did another search and it came up PH3682 Fram for the switch from Hydraulic FILTER FILSTER HST HH660 36030. I will be glad when my owners manual arrives.
   / Need conversion info for Kubota 7200 Tractor #5
Your are taking a big chance on using that Fram filter. Fram lists it for various Kubota engine applications on their www site. It likely simply has the same diameter and thread size as the hydraulic filter. Size and thread do not make a hydraulic filter.
I have been to Aberdeen Proving Grounds to look at the tanks on display, if I'm thinking of the same base. Interesting place!
Yep we had plenty of tanks there and the third largest air force in the world with the number of aircraft stored there.
FRAM filters will stop anything over 5 microns. Might be interesting to contact Kubota and ask what micron level theirs will pass.
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
2022 KMC 21-39-HD LOT IDENTIFIER 183 (A53084)
2022 KMC 21-39-HD...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
