Box Scraper Need boxblade buying advice
   / Need boxblade buying advice #1
AJ07
Wild Peach Village, TEXAS
2005 N.H. TC40A
I have a 40 HP NH and am in the market for a 6' boxblade. This will cover my rear wheels. What size end plates will be sufficient for my tractor? I would like 3/8" thick endplates, is this going overboard? Thanks for any help. AJ
   / Need boxblade buying advice #2
I just bought a new BB this past week after looking at different brands and prices. I ended up buy a United BB from everythingattachments who advertises on here. It seems to be pretty well built and for my needs will work well. Now if I were doing something comercially, I probably would have looked at something that had the hydraulic scarifers.
The price was the best I could find and they have free shipping to within a 1000 miles of their shop.
The only thing I have issues with on the BB is that it came nowhere close to mounting up with my quick hitch. I really did not want to have to cut and weld on it but I ended up needing to modify it quite a bit to fit.
I have a 30hp Bobcat. I don't know for sure what the thickness of my endplates are but in my opinion, I don't think that has much to do with the function of the BB. As long as the frame is built heavy enough, the end plates should not have to be super thick, they just contain the material in the box. Other may have different opinions and I am in no way an expert, this is my first BB.
   / Need boxblade buying advice #3
Hi. Yes , take a BB yhat will cover your tracks. Take a heavy one, no pressure can be put on a BB it,s weight does everything, the ticker the better, it will work hard. Mine is a 6 ft Bushog on a 43 hp tractor (Massey 1643) and work well. Try to pick one with a double attach to your lower links, because you are always pulling and this part of the BB will suffer if not strong enough ( your lower links are attach with a pin between two pieces of metal , look many you will see what I mean ). Good luck and buy the best one your money can get you, you will have it for your life.....:thumbsup:.Roger
   / Need boxblade buying advice #5
As mentioned, on a box blade, weight is your friend, so I would buy as good and heavy as you can comfortably afford. At times I wish I had gone just a little heavier myself. I am adding weight to mine, but ideally that would not be necessary.
   / Need boxblade buying advice #6
we have made box blades, in the past, where the moldboard and sideplates were all 3/8". in the retail market, landpride makes a great piece of equipment. but, you have to jump to the more expensive ones to get the thicker steel.
As others have said, weight is your friend.
   / Need boxblade buying advice #7
I bought the BB2584 which is a pretty nice piece of equipment and weighs 593 pounds. The next size up would have cost much more than I wanted to pay.
We have a ten foot wheeled scraper if needed.
Thanks again, I think I will go for the thicker sideplates. Checkin on Landpride and Woods.
   / Need boxblade buying advice #9
Weight is a box blades friend. Mine is a frontier BB2048 with 3/8 side plates, and is about the heaviest 48" box out there. And yes, more weight would be nice sometimes. Glad I chose the box blade I did.......
The heavier the implement, the more you pay. Especially if its the right brand and color:)
As long as your tractor can lift it a box blade cannot be overbuilt, cause' weight is what makes'em work:D
   / Need boxblade buying advice #10
There are other ways to add weight without paying for the extra costs of thicker metal. I got a pretty reasonable price on my United BB and with its construction, I could easily add more weight to it if I ever need to. So far, I am happy with the job it has done.
I guess my opinion is that if you have the extra money laying around and it is buring a hole in your pocket then pay more for a heavier BB but if you are like me and don't have the extra cash then you can easily add weight for next t nothing.
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
2015 Jeep Cherokee Latitude SUV (A50324)
2015 Jeep Cherokee...
2021 John Deere XUV835M Gator (A50514)
2021 John Deere...
2019 Chevrolet Silverado 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Freeland 100 gal Water Trough (A50515)
Freeland 100 gal...
