Need baler help
   / Need baler help #1
cat2
Bronze Member
john deere 458. I did all 1st cutting hay. Now today sometimes i can do 20 bales, then maybe 2, then maybe 5, then 10. The net wrap keeps wrapping around the rubber roller. In the book it says to loosen the roller, i kept doing that, now you can turn the rubber roller and the steel roller doesn't move. So it doesn't have too much pressure, but why is it still doing this?
   / Need baler help #2
Sounds like the brake needs to be adjusted. It is on the left side of the baler on the back.
D.
   / Need baler help #3
The rubber roller needs to be cleaned with mineral spirits or other solvent. And the net wrap roll needss to be dusted with talc. Put the roll tension back to spec.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51691)
2015 Ford F-550...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53473)
Gooseneck...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
