Need alittle ID help
/ Need alittle ID help #1
BIGREDBOB77
WESTERN PA
19-- FORD INDUSTRIAL
I am looking to pick up this Ford Industrial tractor hopefully this week,nothing big broken,runs,nothing crazy.Can someone help me determine what model,year and anything else about it.It appears Industrial tractors are harder to id then ag tractors. TRACTOR4.pngENGINEID.jpgAXLEID.jpgTRACTORSERIAL.jpg
TRANSID.jpgView attachment 515795
/ Need alittle ID help #2
Scroll to the bottom and follow the link and you will see your info. I pasted the pertinent info here
You have a model # of 41105
(4) Suggests 172 CI engine
(1) industrial or ag made after 1963
(10) suggest row crop, but that doesnt look to be a row crop
(5) suggests Select-o-speed with 540 PTO and hydraulics
Could be a tranny of a different tractor
Decoding the 5 digit model numbers on 2000-4000 series tractors -
First number (1 digit)
2**** - 134 ci gasoline or 144 ci diesel engine
4**** - 172 ci gas, LP-gas or 172 ci diesel engine
Second number (1 digit)
*0*** - Industrial models produced prior to 1963
*1*** - Industrial and agricultural models produced after 1963
Third number (2 digits)
**10 * - Row crop
**11 * - Offset
**20 * - Utility-type w/adjustable front axle
**21 * - Orchard type w/ non-adjustable front axle
**30 * - Utility-type tractor w/non-adjustable front axle (light industrial)
**31 * - Low center of gravity (LCG tractor)
**40 * - Heavy duty industrial tractor w/sub frame
**41 * - Heavy duty industrial tractor w/sub frame & cast grille
Last number (1 digit)
*1**0 - Four-speed w/o PTO
*0**1 - Four-speed w/o PTO or hydraulics
*1**1 - Four-speed w/PTO
*0**2 - Four-speed w/hydraulics, w/o PTO
*1**2 - Five-speed w/live PTO
*0**3 - Four-speed w/hydraulics and PTO
*0**4 - Select-O-Speed w/o hydraulics or PTO
*1**4 - Select-O-Speed w/o PTO
*0**5 - Select-O-Speed w/hydraulics and single-speed (540 rpm) PTO
*0**6 - Select-O-Speed w/hydraulics, 540 and 1000 rpm PTO and ground-speed PTO
*1**6 - Select-O-Speed w/two-speed (540 and 1000 rpm) independent PTO
*1**7 - Select-O-Speed w/540 and 1000 rpm independent PTO and ground-speed PTO
*0**9 - Five-speed w/live PTO
Suffixes
-1 - Tricycle with single front wheel
-4 - High clearance with wide front
-L - LP gas engine
-D - Diesel engine
Thousand Series tractor serial numbers -
1962 Serial number 1001 - 11947
1963 Serial number 11948 - 38930
1964 Serial number 38931 - up
Part number identifiers cast into 134 and 172 engine blocks (lower right side)
EAE 6015 - 134 1953-1957
EAF 6015 - 172 1953-1957
310905 - 134 1958-1959
310609 - 172 1958-1959
B9NN-6015C - 134 late 1959 early 1960
B9NN-6015A - 144D late 1959 early 1960
B9NN6015J - 172 late 1959 early 1960
B9NN6015B - 172D late 1959 early 1960
C0NN-6015G - 134 sleeveless late 1962-1964
C0NN-6015H - 144D late 1960-1964
C0NN-6015C - 172D-G late 1960-1964
C0NN-6015J - 172 late 1960-1964
Identifying Old Ford Tractors
So I guess its a 1962 model 44105?
It appears my soon to be tractor is kind of a freak.lol
/ Need alittle ID help #6
Many are. Since the trannies and engines and rears from 55-64 all bolt up ( with some minor pedal and spline issues that are managable ), you get lots of frankies.
I have a 950 made of 7-8 tractors.
/ Need alittle ID help #7
It's likely that the trans and maybe the rear have been switched out. Hood color would indicate an 1801. The steering rod would indicate a 4000. So basically you have a 4000 Heavy Duty industrial with an Select-o-speed trans.
Parts on these old fords get switched around quite a bit.
Kirk
/ Need alittle ID help #8
Looks like someone took the row crop front end off and put the industrial front end on the tractor.
/ Need alittle ID help #9
Where do you see that??
The pics Bigredbob77 posted CLEARLY show standard rear axles.. no drop boxes. for it to be a rowcrop rear end.. it would need drop boxes.
/ Need alittle ID help #10
Yeah, looks like a standard tractor with the S-O-S tranny off a row crop tractor.
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63118)
2010 Kenworth T3...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
TRACTOR FRONT GUARD & MISC (A63745)
TRACTOR FRONT...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
