Rotary Cutter Need advise on what rotary Cutter I should buy?
   / Need advise on what rotary Cutter I should buy? #1
Gordo 56
Park Forest, IL
Kubota L3000 DT
My wife has given me permission to buy a new rotary cutter and I need advise on which model to choose from. I want to buy the most heavy duty mower my tractor can handle. I have a Kubota L3000 DT and I have it narrowed down to two brands because that is what the nearest dealer to my property has. I really like the Woods BB 600X for 3,300.00 delivered because it seems very heavy duty. My concern is it weighs 1069lbs and was wondering if I might regret buying such a heavy mower. The other one I am thinking about is the Land Pride RCF 2060 for only 2400.00 delivered. It weighs only 690lbs. I have lots of brush and small 1 1/2 to 2 inch willow trees on my land and this land is in Iowa with some pasture on some hills.
I have an 5 ft Old Mott Flail mower now that I use and it does the job but the brush and trees knock off some of the blades sometimes. What mower should I buy for this tractor? I have pictures below of what I have to cut. P4140006.jpgP4140016.jpgP4140017.jpgP4140023.jpgfarm pictures 010.jpg
   / Need advise on what rotary Cutter I should buy? #2
My Kubota B3300SU almost mirrors the stats of your L3000DT.
Tractor Data shows the L3000 to be 51" wide, so I presume you are shopping 60" Rotary Cutters.
With 27.5-HP/PTO when new, less now, I doubt if your tractor has the power to spin up a 1,069 pound cutter.
I expect the Land Pride at 690 pounds will work better for you.
It is pointless to have a Rotary Cutter that you cannot spin at optimal speed.
Land Pride and Woods are both well known for Rotary Cutters.
I cut up to 1-1/4" saplings with my 48" King Kutter Standard Duty L48-40.
I would think the Land Pride R/C would handle 2" soft willows fine with tractor covering the ground at slow speed.
Does your L3000DT have Position Control on the 3-Pt.? If not, you will need to consider Limit Chains such as Zercos, which would be another reason to favor a 690 pound R/C over a 1,069 pound R/C.
What advice did the dealer give?
You may want to call Tech Support at Woods and Land Pride for their recommendations.
   / Need advise on what rotary Cutter I should buy? #3
If your cutter is going to be sleeping outside consider a 5' Modern. They are heavy duty, seal welded and hot dip galvanized. They come standard with a heavy duty gearbox and PTO clutch.
Dealer said he thinks it would be no problem for the Heavy Duty Woods cutter for my tractor, but he is trying to sell me. I am thinking you are right about the lighter cutter, and will probably go that route. Thanks for your advise.
   / Need advise on what rotary Cutter I should buy? #5
Gordo,
I don't see why you can't go with the heavy duty cutter. You "shouldn't" have a problem with spinning the blades at the proper RPM. The heavy duty designation mostly refers to thicker steel, stronger gear boxes, heavier duty componenets, but all else equal, it should be able to spin a 5' heavy duty mower similar to a lighter duty 5' mower. You may notice a bit of a difference with it getting up to speed, but you should be able to use that cutter just fine. The extra weight becomes a problem when referring to 3 point lift capacity and a rather lightweight tractor. A 1k lb cutter would seriously be a handful for your tractor, but you should be able to handle it. if you need the extra cut capacity and overall "toughness" then go with the heavier cutter, if you don't need that and your just cutting small brush and not hitting many rocks and stumps, then go with the lighter cutter. If your thinking of upgrading your tractor over the next few years, definitely go with the bigger one.
In my opinion, your right on the fence with which cutter you could go with. I personally would go with the heavier one, but I am usually overkill with what I recommend, so take it with a grain of salt.
Also, I haven't looked at the specs/model numbers, but I thought the RCF was a finish mower?
   / Need advise on what rotary Cutter I should buy? #6
Woods makes the better chopper period, and for heavy brush, it's the better option.
The power of your bota should suffice, but expect a slower spin up than with lighter units.
The advantage goes to more rotating mass, when working with less PTO power.
You just go slower in the heavy stuff, and let the rotating mass work for you.
The BIG disadvantage, comes when loading the thing on the trailer, and operating on loose ground.
The tail will wag the dog, and front weight will be needed, as well as brake steering.
Dunno how far away you're located, but Woods Brothers(Alf Woods implements) in Bangor Mich. is closing up, and closing out the inventory at bargain prices. The owner had some recent health issues, and wont sell what he can't service, so he's closing shop.
There was a 5' extreme duty Brush bull on the lot this afternoon, that wasn't sold yet.
If it's worth the drive, give them a call.
   / Need advise on what rotary Cutter I should buy? #7
Landpride makes a RCR 2660 which is their medium duty cutter which would be plenty for what you need to do. It compares more to the Woods cutter you are pricing.
John
   / Need advise on what rotary Cutter I should buy? #8
I addressed this on another site, OTT and if your hills are very steep, a lot of weight on the back can really affect stability. I run a cutter that weight on my L5740 HSTC Land Pride RCR2672 and have to have the FEL on or a LOT of front weights and it is quite a bit heavier than the L3000DT. I am sure the tractor will spin it, but the weight concerns me if steep hills are involved.
   / Need advise on what rotary Cutter I should buy? #9
GORDO: Find out if your tractor has POSITION CONTROL on the three-point-hitch.
   / Need advise on what rotary Cutter I should buy? #10
I have an 5 ft Old Mott Flail mower now that I use and it does the job but the brush and trees knock off some of the blades sometimes. What mower should I buy for this tractor? I have pictures below of what I have to cut.View attachment 335405View attachment 335406View attachment 335407View attachment 335408View attachment 335409
As you already own a Mott flailmowe;
You also should consider a Caroni rough cut flail mower.
Their two row flailmowers have hardened side slicers and we have many
happy owners of this model on the forum.
The Caroni TM1600BSC model has a 63 inch cutting width and has 2 row flail mower rotor
with 24 mounting stations using shackles to attach the 48 hardened side slicer knives.
This model wieghs in at 628 pounds.
Sundowner Rancher Express 20FT Livestock Trailer (A56435)
Sundowner Rancher...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
American G-Model Pump Jack (A56435)
American G-Model...
LOT: Dewalt Electric Sawzall, Craftsman Palm Sander (A59076)
LOT: Dewalt...
