Need Advise on relocating hyd ports
   / Need Advise on relocating hyd ports #1
Toffy
I have a 445 John Deere that has the hyd ports below the cab on the left side. I would like to put couplers on the back end so i could use other implements. I have long hoses that go to the back but quite often i find this frustrating to install as i have to run them under the tractor. Any ideas what to do. I still need the front ones for my loader and blade attachments.:confused:
   / Need Advise on relocating hyd ports #2
depending on your quick connects you could tee into each line and run hoses to the back, instead of plugging in and running hoses each time, i am guessing your using the loader valve to control your rear emplement? I installed a third function electric valve for a grapple on my FEL, and ran a set of hoses teed off to the back works good
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
