Need Advise on relocating hyd ports
   / Need Advise on relocating hyd ports #1
Toffy
Bronze Member
I have a 445 John Deere that has the hyd ports below the cab on the left side. I would like to put couplers on the back end so i could use other implements. I have long hoses that go to the back but quite often i find this frustrating to install as i have to run them under the tractor. Any ideas what to do. I still need the front ones for my loader and blade attachments.:confused:
   / Need Advise on relocating hyd ports #2
depending on your quick connects you could tee into each line and run hoses to the back, instead of plugging in and running hoses each time, i am guessing your using the loader valve to control your rear emplement? I installed a third function electric valve for a grapple on my FEL, and ran a set of hoses teed off to the back works good
2011 Homesteader Box Trailer, 6'x10' (A52384)
2011 Homesteader...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
