Need Advise, deck repair
   / Need Advise, deck repair #1
HokieMS
Buchanan Va
JD 4005
I need a bit of advise. I recently purchased a 1995 Craftsman GT (dark green, with square hood).
https://www.dropbox.com/s/ncxyeldb49bfnso/IMG_20150605_181542944.jpg?dl=0
I got a good deal on it, and it is in fantastic shape... except one thing I just found tonight. I bought spare blades for it, and while changing them out tonight, I found end of 2 out of the 3 mandrel shafts has the star pattern worn almost completely off. The third shaft has a slightly rounded off star pattern.
So... I have found the shafts on searsparts.com, but my question is: should I bother buying any of the bearings, or just go with what it has now? The blades turn easily by hand, and I can't feel any bad spot in any of the bearings. How easy will it be to break a bearing when removing the shafts? I will definitely replace the bolts and washers, no question. Anyone who has any experience replacing these shafts, please chime in. I don't mind buying more parts if I really need them, but I also like saving money.
Thanks
Mark
Edit: I was trying to save money, but maybe I'll just buy all 3 mandrel assemblies instead... crap. That would just be less to worry about, I guess.
   / Need Advise, deck repair #2
If it was mine, I would remove the deck and just change out the shafts. No need to remove the mandrels to do this.
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
City of Lakeland (A51691)
City of Lakeland...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
