Need Advices on a John Deere JD770
   / Need Advices on a John Deere JD770 #1
WiltonLee
Wilton, CA
JD770
I had recently move to the country side and very inexperience about tractor or how to operate. I bought a used JD770 model and had been using the tractor out in the field for a small garden. Recently, my tractor stops moving. I had just replaced the battery and all electrical and hydraulics are working fine. The engine runs great, but when i put into gear to drive, it is not moving.
Is this result of the clutch running out when the tractor is not moving when i put into gear? If it is not the clutch, is there something that i am not operating correctly?
If it was the clutch, what would normally cost me to get the clutch repair and replace?
Your advice are greatly appreciate it.
Thanks,
Lee
   / Need Advices on a John Deere JD770 #2
Just a thought, but is it possible that the lever for the Low/Neutral/High range is in the middle position? If it is, that should be neutral, like it is on my 790, which would not let you move anywhere.
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
LOT: Torch Cart w/Gages, Hose, Torch Head (TANKS NOT INCLUDED) (A59076)
LOT: Torch Cart...
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
NEW Fork Extensions (A59000)
NEW Fork...
