Need Advice with Mud & Horses. Rookie
   / Need Advice with Mud & Horses. Rookie #11
Some folks out on the highway tried to keep horses on a too small piece of land. Eventually the whole place washed out and is now just unusable for any purpose. Horses need a lot of space and you really need to be able to rotate them in and out of pastures to allow the grass to recover.
A lot of good posts. So thank you, keep them coming. I'll see if I can add more info to address some and maybe it'll help direct me even more.
So, I say it drains okay. By that I mean, if I can get a week without rain, the mud dries up pretty well and I can go walk on it without sinking in at all. And it appears dry.
BUT. A big but too. I live in Western Washington. Enumclaw to be specific. Fall through spring it rains an average of 6 days/week.
I live on 5 acres, I'd say 2.5 is currently usable that I can eventually add more paddocks/cross fencing after I fully fence our property. The other 2.5 acres is trees or our living areas. Eventually the plan IS to make 3 or 4 of these paddocks to rotate them through.
We had 2 horses and a pony...
But a month ago my in-laws brought their 32 year old mare over "temporarily" while they worked on moving to Arizona, then decided they didn't think she'd survive the trip or heat down there, so now they're basically leaving her for us to take care of. So now its 4 sets of hooves.
Additional question. When you guys mention subsoiling through the hardpan... I live on a very rich aquifer. I almost wonder if parts of my property are above a spring. I've never dried my well up and have accidentally left the hose on 12 hours in the summer, I don't have a water tank on my well system. If I subsoil through the hardpan.... will that actually help it drain? Or would it just introduce more water from below? I'm not sure how that works.
The areas the horses dont walk in much are pretty dry and hard even through the rain, it's really just their main leisure areas. By the gates, shed front half of paddocks. The back halves they only walk around enough to finish off whatever grass may be popping up.
i forgot to say if this mud is mostly manure then yes scrape it down and use it to fertilize your field in the fall…
It's not. Its mostly just dirt mud, but there is manure in with it.
If you get a few cases of foot rot, life will change. Horses can go through mud but they don't do good living in it. Cows also. When they get lame, you realize how big they are. My oldest horse is a 94 model. He is not in mud unless he wants to be. Still in good shape and healthy.
Yeah and that's what we want to prevent. Luckily, the do have drier, less muddy areas in their current spaces they can go to, so we haven't seen hoof problems yet thankfully.
Here's a pic from this morning from the other, lower end. Much drier towards me and not muddy, but wet up above by the shed and water trough. 20220511_083231.jpg
   / Need Advice with Mud & Horses. Rookie #15
you could elevate with sand or gravel around the feeding area and shelter with a path from these places and to the gate just 2 to 4 feet wide, it would solve most problems for the rainy seasons.
   / Need Advice with Mud & Horses. Rookie #16
Horses' hooves and mud are mutually exclusive for good health. Like some others have said, acreage is the key, so they don't end up on bare ground. However, you do need a dry lot for those times they need to get off the pasture. There's a reason most horse ranches cluster around sandy soiled areas. You'll probably need to excavate out to a certain depth and then layer in a slope draining 1 1/2" base, then some type of 1/2 - 3/4" base, then a sand layer. The kicker is then containing it from washout. Anything can be fixed with $$$.
I'm so new and quite honestly ignorant to a lot of this. I read the term washout a couple times... what does that mean exactly???
The spot where it's muddy IS the higher ground, should I make it higher??? The dry area is about 2-3 feet lower.
   / Need Advice with Mud & Horses. Rookie #18
From Debbie Downer... It is a very wet part of the country. You have more hooves than that small plot will ever be able to handle. Something has to go, be it a few horses, your current location, or most of your bank account. And even if you clean out your bank account that small area cannot hold that much.
In urban areas horses are confined to their stall almost all day as there is nowhere for any loafing area - not enough real estate. You could keep them confined and do a lot of shoveling while you generate tons of manure for disposal. You will also develop a fly issue with 4 horses pooping as fast as they can.
Welp..... I guess maybe my best course is to just stick with the plan to eventually make some more paddocks to rotate eh?
Should I even scrape any dirt out or just back blade to pack it back down when it dries out a little? Or... what ideas for when it does dry out.?
I need to come up with a proper plan of attack and maintenance I suppose.
Money is a factor, I don't have the funds to dump tons into it, but I'm not saying I'm broke either. We can afford the horses, the medical bills all that. But we have other things to budget for besides mud.
   / Need Advice with Mud & Horses. Rookie #20
You should do the "planned"expansions and fencing now,not in the future. Vist local horse professionals and follow their methods of keeping horse hooves dry. I think you will see large stalls inside buildings,covered paddocks,concrete topped with sand that is periodically changed out. They will also have daily exercise programs in covered arenas in wet weather and outdoor arenas in dry weather. With any pet comes responsibilities,larger and multiple pets usually equate to larger and more responsibilities. Let's face it,some of us are not up to the task for owning a goldfish,much less large or multiple pets. Consider this. Wild horse and burro populations must be controlled to prevent hoof damage to vast open range country. Look more toward reality and less for silver bullets.
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
10' Fork Extensions (A53316)
10' Fork...
378908 (A54865)
378908 (A54865)
2015 International DuraStar 4300 Johnston VT651 8.5 CuYd Street Sweeper Truck (A55788)
2015 International...
International 404 Tractor (RUNS) (A50775)
International 404...
(2) Hydraulic Cylinders (A53316)
(2) Hydraulic...
