Need advice Replace Lift Seal on 1710
   / Need advice Replace Lift Seal on 1710 #1
hgqed
SC/FL
Ford 1710
I have a Ford 1710 and the lift leaks down moderately when the engine is cut. Assuming the main seal is the culprit it does not look like too much trouble to replace.
Seal is $13 and o-rings together are $14 plus S+H.
Question: Are any special tools required? Knowledge needed to pull the parts out. Looks like the head bolts come out and then the cylinder etc. In fact this looks all to simple so I thought I壇 ask of someone who has been there.
Also, are these parts sold as a kit and is there a best buy recomendation? No rush as I won't do this for a month or so.
   / Need advice Replace Lift Seal on 1710 #2
Welcome to TBN blue,
It is a perfectly simple task to do and no special tool is needed. Frankly it is ridiculously simple:D:D. I have couple of links below with some help. it is more information that you need but it's all good.
JC,
http://www.tractorbynet.com/forums/new-holland-owning-operating/90819-my-f-1700-testing-my.html
http://www.tractorbynet.com/forums/new-holland-owning-operating/88973-sos-i-have-my-first.html
Ah, simple indeed. I think I'll raise the lift and tie it up to prevent the rod from falling on the inside of the cylinder and possibly scratching it. Other than the expected mess, what could go wrong. Thanks, excellent photos. I'll remember to bring my camera.
   / Need advice Replace Lift Seal on 1710 #4
As JC said it is a simple job. My tractor is 4x4 so I had to take 2 of the bolts out of the 4wd shifter for clearance.
Bill
   / Need advice Replace Lift Seal on 1710 #5
Ah, simple indeed. I think I'll raise the lift and tie it up to prevent the rod frm falling on the inside of the cylinder and possibly scratching it. Other than the expected mess, what could go wrong. Thanks, excellent photos. I'll remember to bring my camera.
To avoid the mess I have done exact the opposite and lowered 3 all the way down. The push rod and the picot arm is pinned to rockshaft solidly and it is so blunt that I see no chance of it scratching the inner surface of the cylinder. just make sure the lips on the piston seal face the cylinder head. It will be tight, don't heat it up. I lubed it and tried to spread the pressure squarely and evenly. it is a one shot deal, put it in incorrectly and you'll buy another seal.
JC,
Year: 2008 Make: International Model: 4300 Vehicle Type: Truck Mileage: 141781 Plate: Body Type: (A51692)
Year: 2008 Make...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2017 International DuraStar 4300 26FT Box Truck (A51692)
2017 International...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
