Buying Advice Need advice on tractor
   / Need advice on tractor #1
asylum
There is a Yanmar 187D for sale locally (Western PA). It has a loader and a backhoe. Around 600 hours. The houseing on the transmission is cracked below the driver's seat. So it needs repaired. The guy wants $6500 as is. All works fine except for the repair needed on the transmission case. Is this worth the price?
   / Need advice on tractor #2
that's just insane,.........asylum. Sorry, couldn't resist. But that is a lot of $ for a tractor that size with a cracked housing, in my opinion. Probably caused by the backhoe(?). You should get the extent of damage checked out and determine cost of repair first.
Bill
   / Need advice on tractor #3
If it's the same gentleman I talked to, the case is broken from the stresses of the back hoe. He had a complete replacement parts tractor (in PA?) with a transmission gear problem. The dealer wanted $1800. for it.
I think, unless you are mechanically confident, in no hurry and can negotiate a much better deal, You might just pass this one by.
Yes, I thought he was a little insane on the price as well. I just needed some confirmation.
thanks
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
