MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,619
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Nice looking machine, ETO. :thumbsup:
I found a John Deere 302 with a FEL and scrapper for $4800 asking. It has 3300 hours with a 3 pt hitch and PTO. Any known pro's VS con's on this industrial tractor?
I don't mean to rag on Eric (much) but I cannot buy his explanation that he is bumping over skidsteer tracks nor do I accept Moss's explanation.
Look at the video starting at about 55 seconds through 1:20 or so. YouTube Link: https://www.youtube.com/watch?v=1ZwojVPmgd4 The ground is smooth and until he hits an unseen object there is no camera jiggle. The tractor jolts to a stop. He then backs up and drives forward again with the exact same result. On the first attempt it sounded like the tractor might even stall and the tractor definitely came to a complete stop, it did not "bounce" over a rut. Anyone who clears brush knows that clumps of "saplings" are often shoots from an old stump so just ramming it without inspecting or even bothering to figure out where the contact point is is just asking for trouble.
I am persisting only because I think a lot of new owners watch these threads to learn how to do tasks associated with land clearing. The CUT can be used to clear land but like any tool there are proper and improper ways of using it. Eric shows us the "don't do it this way" approach. You use a knife to cut and you abuse a knife if you try to turn a screw with it. Same story here. Rather than pretending he was driving a bulldozer (his technique is fine for a real bulldozer with short fat "FEL" arms) he should have more gently explored the poorly visualized clump of saplings with the bucket and once he made contact at low speed and determined that the obstacle was midline on his bucket, he could have pushed slowly or better yet lifted/curled. It can be done safely with either a bucket and toothbar or preferably with a grapple but the key is that you DON'T RAM BLINDLY with a CUT FEL. A bulldozer rams because it is designed and built to do exactly that. A CUT FEL is designed and built to lift not ram. Simple concept. Little saplings are not the issue but anything that stops the tractor dead needs to be 1) properly identified, 2) line up so the object is mid bucket/grapple, 3) use the curl/lift power of the loader to pull the sapling/object out of the ground rather than simply pushing on it.
I think even Eric would agree that the technique he showed in the video is unlikely to be good for the tractor/FEL. A $35K tractor may be a toy that can be abused for some folks but if you want that tool to last and not be in the repair shop constantly, there are more appropriate techniques to use for clearing brush.
You're thinking too much. I see a wall of green. I'm using the BXpanded bolt on toothblade exactly the way it is supposed to be used on 2" and smaller material. Right before I made the video, as a test I sheared off a 3" pine like it wasn't even there. The stuff you see me hitting repeatedly is a stand of thick poplar. The loader has a breakout force approaching 5,000 pounds and can lift 2900 pounds all the way up. It is a much heavier loader than what is featured on smaller tractors. The whole point of the BXpanded piranha tooth bar is that it has a hardened, serrated, sharpened edge for cutting through material as demonstrated in the final section of their own demo video.
That said, bumping things out of the way is both slower and messier than rotary cutters because you wind up with a pile of dirt and unprocessed material at the end of each push that eventually needs to be cleaned up. I've found it is faster and takes less clean up using a heavy rotary cutter.
Additionally, for those who have paid attention to the My NX6010 thread in the Kioti section, you've probably figured out by now that I can likely fix anything at the Tinkerage.
It looked to me like the operator repeatedly rammed the tractor into an immovable object, perhaps lifting the rear wheels off the ground. At any rate, it bothered me that the vehicle was being used in such a manner...the shiny paint and uncracked windshield are surely no longer so pristine by now! All the giggling reminded me of my grandmother's saying, "he has more money than sense!"
(Edit: just saw that this tractor comes with either diesel or gas engine. I was assuming diesel. Not so sure about 3300hrs on a gasser though that would be cheaper to rebuild).
