need advice on pressure line
   / need advice on pressure line #11
You can't just put holes in that plate, it has to be a new one made out of some flat stock.
   / need advice on pressure line #12
I would just cut the supply to the 3pt add some compression fittings and some QD's and be done with it, except for running the BH return to a return line or the filler cap.
Many people have used the filler cap for return.
If you added just one aux detent remote, you would also be setup for BH use.
Now you have a return line on the back side of the picture you just posted. It might be just a rubber plug.
Wow! you are so right Leejohn. I removed the rubber plug and the hole itself is smooth bored. Excellent spot for some kind of rubber plug with hose mounted in the center of it to be pushed in. Wonder if they sell a plug/return hose assembly. Will search around. You're very observant, thanks. On another note, I spoke with a woods rep today and he sent me a pdf. for hose mounting kit instructions for the 90bhx and mounting instructions for the four point sub frame. If memory serves me right the pb hose comes off at both ends- the block and the loader valve. After changing out a few adaptors that come with the hose kit it's pretty straight forward: 49" hose goes from pb on block back to bracket mounted on rear end, and the longer hose (122") goes where the pb was removed on the loader valve and goes all the way back to a QD connect mounted to bracket (with bulkhead adaptor) on the sub frame. Oddly, it seems the return juice has a long long way to go to get back to the tranny via a 122" hose all the way back to the loader valve assembly and back down to the trans.. It seems this route would not offer as much resistent free flow when comparing it to that rubber plug location. I mean it would have such a short shot it would have to be all good, less travel equals less heat I suspect. Only problem i see with installing a return at the back of the tractor is that I wouldn't know what to do with the pb port on the loader valve after removing that hose. Do I just cap it? Thanks Leejohn and sorry it took so long to respond to your threads..........
   / need advice on pressure line #14
Wonder if they sell a plug/return hose assembly. Yep, hose #140 page 52 on the parts page
Something is not right here.
The flow is from the pump to the hyd blk and then to FEL, and FEL PB back to hyd blk, and then to 3pt.
You can't block PB from FEL.
I sure thought I put everything into perspective.
I am going to give up here and let you guys figure it out.
You're right JJ. I think outside the box too often and try one's patients to the point of frustration. I am just going to get the subframe and hose kit together and do the simple install per instructions. One long hose back to a QD mount, and one short hose back to a QD mount (from loader valve pb, and from hyd. blk. pb). The ends of them are male and female as are the two hoses on the back hoe. When BH is removed from tractor you simply plug the two hoses mounted on the tractor together
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
20711 (A50323)
20711 (A50323)
1268 (A50490)
1268 (A50490)
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
