Need advice on pond project
   / Need advice on pond project #11
CPA--
We dug a huge pond last week in south central Ohio. Before the digging: we (me and my son) cleared the trees; saving all the logs with the tops cut into firewood. We used a compact track loader (CTL 289C) to pile the logs distant from the pond area and trucked the firewood closer to our house. I pushed the remaining branches/brush into huge piles for burning in 2-3 months. No need to grind up branches....just burn them. This took about 3-4days. So---the stumps remained in place...for about 2 days. Next, I rented a excavator (JD200) and dozer (JD650) for a week. It took the excavator/dozer maybe 3 hours to up-root the stumps and push the stumpage into a ravine (distant to the pond area). Check to see if anyone buys stumpage in your area. Grind up the stumps? Spend your money digging a pond, not grinding branches/stumpage. IMO, the excavator is the way to go....move lots of soil quickly for the dozer to push, grade and compact. The dozer and CTL could not keep up with the excavator. I like jennings comment...some stumps can be left for fish cover.
Good advice above. My pond is at a site on my property that has a high water table year round - within a foot of the surface. I dug a test pit last sping and confirmed my suspicion that the water table was high. It held its level constant throughout our summer, which was very dry. The groundwater is such that I put in a shallow well to 45' and it is a flowing well. I also have an area near the pond site that has water coming to the surface and running into a nearby ditch. Lack of water is definately not a problem on my property.
I did have the woods logged extensively last year - about 300 trees. There is still some marketable timber standing that I'm having a forester come look at. Hopefully it will provide some operating cash.
   / Need advice on pond project #13
We are in process of doing about same but enlarging current pond rather than digging from scratch. Did not see what you will do with dirt and it may make some difference in what you do as to equipment.
If I wanted the stumps out, take them out with excavator before you cut trees. To me much easier if possible than digging just stump as the tree's weight helps as has been said pop it out. If you will be burning the stump, you need the limbs in the pile to provide fuel for those stumps. Large wet stumps are not quick to dry or easy to burn. Hey still there. Is it safe to burn there and is it legal? Ask, don't assume. Happen digging.
   / Need advice on pond project #14
The high water table may cause allot of problems. If you build a dam, then the water will lower down to the level of the water table. It's not always a good idea to build on springs or wet areas.
Saying that, I built my pond in a wet area. At first, I didn't know how I was going to accomplish it, bu figured I'd work around the edges of it, and keep going in until it was too wet to go any further. I was hoping for 4 to 6 feet of depth, but wasn't sure how I'd get rid of the trees in the middle. As I cleared the land, and the ground became exposed, it started to dry out. The more I cleared, the better it got. Then as luck would have it, we started the first year of two years of a very bad drought. I got very lucky because it took my two years to build my pond.
During my digging, I also compacted the bottom of it. I also found the springs, which were on the side or shoreline of my pond. That's about where my full water level is at. Again, I got lucky in my plan so that it worked out this way.
If the springs had been lower, then I would have had to dig them out and pack them with clay. Water will go in either direction, depending on the amount of force on it. Put a million gallons of water above a spring, and it will become a drain.
As for your original question, there are a couple ways to do this. If you have it logged, have them take out the sumps at the same time. Around here, I'm told that the cost of the timber will offset the price to clear of stumps and make it ready for pasture. It's an even trade and you don't make any money on the logs, but you end up with a clear field. Having to remove the stumps after it's been logged is expensive and time consuming. It either takes a big machine or lots of hours. Either way, it's money out of your pocket and usually more then you can get for the logs.
A decent pond builder shouldn't have any problem with digging a pond within the boundaries you specify without disturbing your trees. If the water table is too high, he can dig a trench to drain or lower it.
An excavator and a bulldozer could probably do this in a week pretty easily once the trees are out of the way and your soil is workable. If the excavator has to take out the stumps, it will take a little longer. If they are burning, that will add time, but you can use the stumps and/or remains of the burn for structure for your fish. I was burning the entire time that I was building mine, and what was left got stacked into piles for the fish.
Eddie
2020 Case IH Farmall 130A Tractor (A50860)
2020 Case IH...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
2017 Isuzu NPR Crew Cab 14FT Landscape Dump Truck (A48081)
2017 Isuzu NPR...
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
1997 Ford F-700 7 Yd. Dump Truck (A48081)
1997 Ford F-700 7...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
