Need advice on lighting for new Pole Barn
   / Need advice on lighting for new Pole Barn #11
I used LED "ufo" style high bay lights in my shop with 16.5' ceiling height. Work great, used 8 for a 40x40 area but could have used 9 (the garage door made the 9th light pointless).
They have fantastic coverage. With what you're talking about you could probably get by with less fixtures.
Adiding LED High Bay Light,150W UFO High Bay(600W HID/HPS Equivalent) 19500 Lumens 130Lm/W Meanwell Driver Dimmable 5000K,Lumileds SMD 3030 LED for Garage Workshop Warehouse,UL DLC Listed,IP65 https://www.amazon.com/dp/B072QB389F/ref=cm_sw_r_cp_apa_i_UlwuDbSD5HTEP 1392395746.jpeg962555724.jpeg
   / Need advice on lighting for new Pole Barn #12
I installed 15 (5 rows of 3 fixtures) LED highbays in my 40x60x14 shop-not inexpensive but provides excellent lighting.Image1565615900.414846.jpg
   / Need advice on lighting for new Pole Barn #13
Many styles to choose from, based on needs, but for sure go with quality LED's.
I used these when I converted my 8' fluorescent fixtures a couple years ago. Best thing I ever did for my garage! Went with the 5K frosted, very happy with them.
https://www.hyperikon.com/
Some time back I installed a dozen of these 8' LED shop lights in my garage. Literally turned night into day. Easy installation and wiring.
https://www.amazon.com/Barrina-Fixture-8500lm-Daylight-Warehouse/dp/B07JVXLQ8R
I like the idea of these. Easy install and says you can link up to 5 together with the 4 cords which would completely cover the distance of the barn. Would 10-15 of these probably add enough light to a 40x60 15-16 feet high?
I installed 15 (5 rows of 3 fixtures) LED highbays in my 40x60x14 shop-not inexpensive but provides excellent lighting.View attachment 616782
Very nice!
Looks great!
I have been looking at the T8 and UFO style highbay lights. Price on the 72W 8 foot T8 is definitely nice and seems you can get more of them cheaper, but would they be fine under a non enclosed barn under roof? The lean to痴 I値l add to the barn will be enclosed but I think I知 going to keep the 40x60 area I have built now open which is where these lights will be going now to start things.
   / Need advice on lighting for new Pole Barn #15
Look for lights that are "Vapor Proof" rated for damp locations. This will protect you from condensate under the roof and insects. I have the same application for lights over some horse stalls under a lean to.
Vapor Proof LED
   / Need advice on lighting for new Pole Barn #16
I installed two of these and want to install two more when I have time.
Vapor Proof LED
Thanks! Sucks for the extra cost of the vapor proof lights, but I think they should last better after reading on them. I live in a very humid area too so good idea.
Thanks for subbing the video!
I appreciate all the help guys, after watching a lot of videos, researching, and your advice I致e settled on putting up 6 150w UFO high bay lights under the immediate 40x60 and see how I like that and if it痴 enough light for my use, & the vapor proof linear lights under the lean to next year for the horse stalls when we build them. I think you guys helped me from buying and doing some work just to see I知 not happy with the results. Appreciate it
   / Need advice on lighting for new Pole Barn #18
Hi,
Just joined the forum & have been reading the BIY section. I know that this is an old thread, in case someone is searching for info in the future, I thought I'd share my experience. I bought an 8-pack of 8' LED strips similar to the ones linked earlier, but rated at 14,400LM each. Cost in early 2020 was around $170. I replaced 4 175W high bay metal halides with 4 of the LED strips, in a 48' X50' aircraft hangar. The LEDs are quite a bit brighter than the MH were, and the light coverage is much more even (the old MHs tended to 'cone', leaving significant areas relatively dark. When a double 8' high output fluorescent in my work room died, I replaced it with one of these strips, with a significant increase in brightness.
Note that if accurate color rendition is really important to you, you'll probably need to pay a lot more for lights. But for me, these lights are more than adequate for doing any kind of work short of critical finish painting.
I gave one of my spares to my neighbor to replace a fluorescent, and he quickly ordered a full pack to replace the rest of his lights.
FWIW,
Charlie
It痴 been awhile but thought I might update this beings I致e had a couples emails since asking what I did. Beings it痴 just a storage barn I chose to not overkill it but wanted enough I didn稚 need more either. We went with 2 100w Dusk/Dawn lights one on each end since we come and go slot at dark with the horse trailer, and 4 100w 15,000 lumen UFO Highbays. Worked out perfect! We have added on with a 22x60 horse barn/lean to on one side so I I ever decided to enclose this some I might would need to add a couple UFO痴 on the outside ends. Beings it痴 still open though the Dusk/Dawn痴 take care of that for now. Added a picture for anyone else reading this. Oh and thank y誕ll for the help!
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
