Tractor Sizing need advice on Kubota size
   / need advice on Kubota size #11
I don't know how much the BH cost but I was given a price for a B7800 with LA402 FEL for about $15,688 at Gloucester Kubota in VA. The B7800 was just out of my range and I went for the B7610 with the LA352 FEL. The B7610 has done everything I needed it to do so far and the FEL will dump into my pickup truck. Glad I got the B7610 but I still get buyers remorse. I could have gotten by with a BX or a B7510. I think the B7800 is 2 steps up from my needs. I will know in a few weeks when I try to build a riding ring if the B7610 is too small. I have time.
Get what you can afford and don't forget the implements. They do the work.:D
Mike
   / need advice on Kubota size #12
I think you just might be able to swing that deal with the B7800. I don't know how much the backhoe costs. Deen Implement in Texas has a deal on B7800 with FEL, Bush Hog rotary cutter, Bush Hog box blade for about 18k. That makes me think the tractor, FEL, tiller and hoe could be had in your range :)
You might check with Carver Equipment www.carverequipment.com in Dunn, NC. I don't know if you are anywhere close, but lots of folks here on TBN have purchased from them.
Terry
   / need advice on Kubota size #13
newtarheel said:
but I think my budget ($22,000-$23,000) is going to keep me firmly anchored in reality, by which I mean a B7610 (with FEL, BH and tiller)
Finding a good deal on a B7800 may be what you need to get your projects done. I used a B2910 to get my pond built. Pond is still going great after 4 years. One reason to consider the B7800 is BH reach. 90" over 72".
Here are a couple of my project pictures.
http://www.tractorbynet.com/forums/attachment.php?attachmentid=6553&d=1025600295
http://www.tractorbynet.com/forums/attachment.php?attachmentid=14285&d=1058308951http://www.tractorbynet.com/forums/...which I mean a B7610 (with FEL, BH and tiller
I've e-mailed Carver Equipment in Dunn twice for a quote. No response. I guess business must be real good.
   / need advice on Kubota size #15
Some of the smaller features can be very big depending on your intended use.
For example,
1] tilt steering is a great feature if mowing is a consideration.
2] Telescoping 3pt hitch linkage is a big plus if you expect to own numerous rear end attachments.
3] hand operated, infinite speed, cruise control is a big plus for mowing
4] a center PTO is a big consideration if you ever expect to use a front end snow blower or a belly mower
5] HST vs gear is debatable. There are many supporters of both versions.
6] tractor *width* is very important if you have a hilly and uneven terrain and you use the FEL with some frequency.
***[7] H.P., in my opinion, is the variable that matters the most. You can never have enough H.P. [especially for PTO use and FEL lifting capacity] whereas you can have too much tractor. ***
Too much tractor, as explained to me by a friend, has to do with little jobs that occur in tighter spaces. Access is the key. Turning radius [keeping bucket swing in the equation] is a big factor. Tearing up the lawn due to tractor weight may be an important consideration. Storage is certainly important.
The B3030 is a great starting point to begin your tractor pursuit. It has all the best features offered by Kubota. Is it too big, too small, or just right? Once you determine this answer, you are well on your way to identifying the perfect tractor for your property. Keep in mind that your property truly dictates the tractor needed. That's an objective match whereas we all fall prey to subjective thinking. ;-)
These are all the little things that come into play when making a selection. If you feel comfortable buying *used*, it will allow you to be far more selective. Your choice of tractors will increase which, in turn, will widen the selection of features to choose from. Of course, the newer Kubota tractors include many of these features as part of their standard package. In my opinion, I would begin with H.P. as the most important feature. Buy as much H.P. as you can afford while keeping these other features in mind.
All food for thought ....
Best of Luck!
The Gardener
   / need advice on Kubota size #16
While I have no personal interest in the matter, I am surprised they haven't responded. I have emailed them a few times over the years and always gotten quick responses, and always from Steve Carver. I hope you find what you are looking for in tractor and dealer!
Terry
   / need advice on Kubota size #17
i have a b7510 with the la302 loader. i love the tractor and it has performed very well.
there is a dealer here in town (Cola, SC) that put together a b7510, fel and woods backhoe. the customer backed out. i suspect they would deal on it. the name of the dealer is carolina power equipment.
   / need advice on Kubota size #18
cpellis.......
I agree! It's amazing what those little buggers will do.
Eventually did get some fine quotes from Carver. I'm just arriving at my new home in N. Carolina and plan to buy a Kubota soon. I'll let you know what transpires. Thanks, all, for the good information.
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2011 Nissan Sentra (A55853)
2011 Nissan Sentra...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
