Buying Advice Need Advice On How To & What To Mow This With
   / Need Advice On How To & What To Mow This With
Been a long time. Read through all responses back in the day. Tried a lot of things by borrowing from friends or using equipment at their place. Really couldn稚 find anything that I was convinced would work. Just kept on mowing that hillside with my D150.
Got some chains for it and that really helped. Was going well until .. the chains burned up the tranny. Had to replace the tranny and remove the chains. Almost flipped it on the hill one day and I had had all I would stand. With no plan, I sold the JD D160. Then, I began my search again.
I decided I would buy the Cub Cadet Pro Z 148S. Thatç—´ a commercial zero turn with a steering wheel. I called all over the western US and nobody had one of these in stock. I tried to get one shipped. No go. I tried everything and simply could not buy one of these in California. Tried Nevada. No go. Tried Oregon. There was a place that would sell me one, but they didn稚 have any. Finally got in touch with someone with half a brain at Cub Cadet. Was informed that they don稚 sell that tractor in CA because weæ±*e enviro-Nazis in this state and the machine isn稚 CARB compliant.
Found a Simplicity online. Standard Garden type tractor, but 4WD and a mowing speed of like 6mph. Got in touch with some good �l boys at Simplicity. Nope .... won稚 sell in CA. Not CARB compliant either. One fine gentleman at Simplicity suggested I leave California and move to the United States so that I can own a decent piece of equipment. I would have been pissed at him if he wasn稚 right.
Long story short, it was evident that I would need to buy something sight unseen. Took a leap of faith and went back to the Oregon shop via phone and ordered the Pro Z 148s for $6,799.00. Hey!!! No tax in Oregon!!!!
Three weeks later, it arrived in their shop. My cousin in Oregon picked it up for me, 都muggled it into California and brought it to one of his shops in Redding where I picked it up.
I COULD NOT BE HAPPIER WITH THIS MACHINE!!!! Thatç—´ not true. I could always be happier. You know what I mean though.
This thing chews up hills like theyæ±*e nothing. Mowing speed as fast as 9mph. Blade speed is 18k. Itç—´ unbelievable.
If I had to complain, and I do ... I壇 say two things I am not 110% happy with.
1) Deck is rigid. No flex. You can adjust it obviously, but there痴 no lean with the contour or anything. Nothing really to complain about, but on some funky curves, you don稚 get a nice tight to the ground cut.
2) Rides rough. No suspension. Meant for golf courses and manicured lawns.
HEAVY DUTY!!! Seriously heavy duty. The best part is ... what took me 6-6.5 hours + on my JD D160, I can mow in 2 1/2 hours on this thing. I mow my place so framin fast that I致e started mowing the neighbor痴 frontages as well.
If you have hills, this thing is a reasonably priced solution. Very, VERY happy with it.
   / Need Advice On How To & What To Mow This With #102
Yeah! I've got the Pro -Z 160 with steering wheel too, and it's kick-azz! Love it. Sturdy as a tank. Cuts like a wild animal, tall, thick, wet, dry. It makes short work of everything. Be careful to keep the cut grass from the engine deck area where the fans keep the hydros cool, from under the deck. (On my prior Scag Wildcat it had a radiator fan and a closed loop cooling system to cool the engine). The Pro-Z hydros are commercial duty but MUST have sufficient air or they will cook. Air circulation in the area also keeps the engine cooler than it would be if those fins/slots were blocked. Make sure the hydro reservoir is full to the mark when cold too, to start things off right. I tag the plastic reservoir with a black marker so I can see the level mark for full. I use Mobil 1 synthetic at the manufacturer's spec for viscosity.
Yeah, commercial grade decks don't really flex much, but yours is the smallest deck they make for the series, so it's not as much a scalper as the biggest decks are. My 60" deck does OK for it's size, and I have acres of lawn at my two properties to cut so I just go as fast as possible and don't see the details....:laughing:
I've got a couple of other Pro-z threads on this forum. Check them out, and maybe add your input there too. You're almost to America now- keep swimming!:D
White Metal Roof Panels (A55758)
White Metal Roof...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2023 John Deere 333G for Parts (A55315)
2023 John Deere...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2015 Freightliner Derrick Digger (A55973)
2015 Freightliner...
