Need Advice on Finish Mower
   / Need Advice on Finish Mower #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I've got several acres of grass around my cabin that I mow with my 6' rotary cutter. Over the years these acres have become closer to a lawn than a pasture. I keep it cut short. And of course the rotary cutter is not ideal for this and in fact I've worn down the shoes on the front from cutting so low.
So I'm considering a finish mower. I have no experience with finish mowers.
I have found a used Land Pride FDR1672 at a local Land Pride dealer. It is their base model. 6 foot cut. It is hard to tell the unit has ever been used. I'm guessing once maybe. It retails for $2500 and he will sell it to me for $2000.
But I have some concerns. It is rated for 15-40 engine HP. My tractor is 45 HP. Manual says not to exceed rated HP. (PTO HP is 38). So I'm not over by too much but the areas I will be mowing are not a perfect lawn. There are occasional ruts and bumps.
So my question is: Is the $500 savings on the mower worth using it on a tractor with higher HP than it is rated for and on probably rougher surface than it is made for?
Their next higher end mower is the FDR25 series. They do not have a used one on the lot. If I went that route I would get the 7' model which is $3600 new.
Cash is tight but the need is there. Any sage advice appreciated.
   / Need Advice on Finish Mower #2
Are you sure the mower is rated for tractor engine HP and not PTO HP? Even so, if you are mowing often and no limbs, small trees or brush are being mowed you should be fine but take that for what it is, MHO.
On the other hand, my biggest concern if it were me is the smoothness of the land. From personal experience, using a finish mower on less than smooth land is asking for frequent repairs. I did the same, I have a camphouse in the woods and used a rotary cutter but desired a smoother cut so I found a used Bush Hog brand finish mower. Sure the cut was better but I soon realized that it was a recipe for spending money and time on repairs. I sold it and went back to my rotary cutter at that property.
Some say a flail mower is in between the rotary cutter and a finish mower but I have no experience with one.
   / Need Advice on Finish Mower #3
I have a 7 foot Landpride finish mower that I bought used from a client. I Found that it gave me a much nicer cut then my 6foot rotary cutter and that it was more fun to cut with it. I also found that it required more attention then the rotary cutter, and that it was more delicate. Since I had it cutting closer to the ground then my rotary cutter, I also learned what happens when you find a buried 4 inch stump. Fortunately, Landpride has great parts diagrams and Messicks if fast at sending those parts. The biggest drawback is maneuverability. It's not for using around the house, or even mowing around trees. It's great for trails and around the pond.
Then I bought a zero turn and parked the finish mower, and haven't used it since. As much as the finish mower gave me a better cut then the rotary cutter, the zero turn was a huge improvement over the finish mower. I should sell the finish mower and probably will, but I'm not overly motivated to do that just yet.
As to your question about having too much power for the mower, I think that if you keep the grass short, that shouldn't be an issue.
   / Need Advice on Finish Mower #4
Do you have an Agri Supply within driving distance? They have brand new Agmate or Caroni finish mowers for less than the used mower you are considering.
I have the 6 foot Agmate and it's done pretty well so far. I have abused it and mow some areas it wasn't intended for. I'm on my third season with it. I just had to replace the wheels. I should have probably greased them every time I mow instead of a couple of times per season. I also just noticed some rust on the deck beside the wheel support so I'm going to have to clean that and paint it. I leave it outside. It is a super quiet and smooth running mower for less than $1500. Agri Supply keeps the common parts in stock for it.
I'm opposite from Eddie. I got rid of my zero turn and started using the finish mower. I like the rear discharge and having the dust cloud behind me in dry weather.
I also have a jd725 front mount mower for close up work but I could get by with just the finish mower and a weed eater.
Thanks for the advice guys. I would really like to have a better looking cut in this area but at the same time 2 grand is a lot to drop on a mower that may or may not be right for the job. $3600 is even more to drop on a mower that might or might not be better for the job.
The two biggest problems with the rotary cutter are that in order to get a nice low cut the shoes are almost on the ground and up front they often dig in and cut into the ground. In addition to messing up the grass that has also worn the shoes out in the front. They wore so thin that they eventually peeled off and there is a good 8 inches missing on both sides. I really don't want to spend the money having the old shoes cut off and new ones welded on since if I use the rotary cutter at heights appropriate for it the wear wouldn't be an issue. In the meantime I'm probably just going to bolt some angle iron into the gaps where it peeled off.
Hard decision here.
Land Pride makes a heavy duty finish mower with swinging blades which would probably be ideal......it is $5500 for the 7'. That aint going to happen ;-)
   / Need Advice on Finish Mower #6
Take a look at the 6' Agmate. They are showing 9 in stock at the Florence SC store.
   / Need Advice on Finish Mower #7
N80...I have 7' Phoenix mower (made by Sicma, which is an Italian import brand, and popular here) on my 38hp, 33 hp PTO and have no problems with it. I can adjust the height from 1.5 inches to about 4 inches of cut. Have 4 floating wheels and an anti-scalp roller to work well on uneven ground, which I have over 10 acres. It also came with sealed bearings for the 3 rotors. Cost me $2100 new.
With your added horsepower, I'd strongly recommend getting the 8' version if the budget allows for it. Of course it also depends on how dense any trees are on the property. I wish I had gotten the 8' model. Tractor would handle it no problem. I would think 8' would be easy for your 44 hp beast.
   / Need Advice on Finish Mower #8
The 5' Caroni we bought new around 1991 is just about to be retired. That deck resides on the Ford and is a backup (and has been abused badly). I've had a 5' LandPride AT on a B7500 and a 6' LandPride 1672 on the L3200. LandPride makes nice equipment and they worked fine.
Last Summer I bought a Caroni 91" RFM that needed some love, knowing we were going to replace the L3200 with something that would have a cab and a few more horses. It took a couple bearings and misc things. For convenience I added the extensions for the spindle greas zerks. The 6' LandPride was used on the L4240 several times until the 91" Caroni was ready. It worked OK on that tractor.
The 91" Caroni is right at home on the L4240 and it works great. I did leave the deflector off the back because it distributes the clippings better without it. This is the best mowing combo I've used since building here in 1989. The Caroni decks are lighter and not as beefy as the LandPride decks. Still love them. A week ago there was a used 5' Caroni on Craigslist and I snapped it up. It will replace the original one on the Ford and since most of the Caroni parts swap I'll have spare parts on hand. Here's a shot of the re-done 91" Caroni.
   / Need Advice on Finish Mower #9
If you don't mind using a flail mower that is used a JD25A or the JD290 finish flail mower would work well for you. It is shorter in total length and you will be able recut the clippings a second time if the grass gets ahead of your mowing schedule.
As far as needed power for the JD25A or JD290 finish flail mower; my father used his Ford Jubilee to power his 25A with no issues and you will be able to maintain a 2 inch cutting height at the rear roller is used to regulate the mowing height and also give you a striper at the same time.
   / Need Advice on Finish Mower #10
I'm surprised Land Pride specs engine hp for their various mowers. I doubt being over the recommended hp is that big of a deal in anything close to a lawn environment.
I would personally would not consider a 6' mower if my machine were capable of a 7 or 8 foot mower though. I will add that on rougher terrain air tires will give a smoother cut without beating up the mower as much.
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
2005 Ford Escape XLT SUV (A56859)
2005 Ford Escape...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
