Mowing need advice on finish mower
   / need advice on finish mower #11
i'll mention something no one else has yet. part of it has to do with the gear box on the mower, the blade length (tip speed) and belt and pulley system on the mower.
my little 42" deere/scotts has two blades and is driven by a 17 hp kohler engine that runs the mower as well as provides the forward motion for the tractor. it is very hard to bog down and has lots of power. gas engine runs at higher rpms. the blades length (lever arm) makes a big difference in heavy grass.
generally i would prefer to have fewer, longer blades to get faster tip speed, but of course, that takes more horsepower since you rapidly loose the leverage advantage. also fewer blades to sharpen and replace. beware of narrow three blade decks due to the shorter blades.
our kubota has a 60" belly and works great. it also runs off the mid pto which is about twice as fast as the rear. have never bogged it down, even in heavy grass. 17 pto hp, diesel engine. it does tend to lay down heavy wet grass as opposed to lifting it and cutting it.
i would see if you can test drive some different configurations on your tractor to see what works best for your combination of pto speeds, terrain, and mowing chores.
   / need advice on finish mower #12
I have a 60" wide Landpride rear discharge finish mower. I was always able to cut in 3rd gear low range with the B6200 I had before. It was working fairly hard in heavier grass but never had to gear down. It was rated 15 HP and I think 11 or 12 on the PTO. Not much difference from your tractor. I had a FEL on that tractor that helped control the mower weight.
Very happy with the mower overall, it's well built and so far problem free.
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
iDrive TDS-2010H...
