Need Advice on FEL Valve Replacement
   / Need Advice on FEL Valve Replacement #1
dMartin18848
Towanda, PA, USA
Mahindra 2615HST with ML106 and 3710 Backhoe
I have a 2005 2615HST with ML-106 FEL and 3710 BH
The front end loader control valve (Nimco 10373-2S) is needing replaced. I am thinking about building a stack from Surplus Center ... or if you know someplace better let me know ... I am not a hydraulic expert by any stretch.
I am thinking I want a 4 spool Open Center with/Power Beyond.
Spool 1: DA Cylinder with Float (Raise, Lower and Float bucket)
Spool 2: DA Cylinder Spring Centered (Dump and Curl bucket) ... do I want with detents?
Spool 3: DA Cylinder Spring Centered (Front remote/Grapple/Brush grabber tool) ... do I want with detents?
Spool 4: DA Cylinder Spring Centered (Rear remote/Snow plow) ... do I want with detents?
What size Inlet, Outlet, Power Beyond and Work ports are on the existing Nimco 10373? I can't find hardly any information on that valve assembly.
Can I just get a 3 spool and plumb T fittings going forward and backward to the 3rd spool if I only plan on using one or the other anyways?
   / Need Advice on FEL Valve Replacement #2
An FEL loader control valve isn’t a stack style and trying to do that (separate levers) would drive you nuts. If the valve needs to be replaced just find one that will flow at least 8-10 gpm. Getting the factory valve will, no doubt cost more but you won’t be fabing brackets and possibly adapting hydraulic fittings.
From the power beyond line (pressure leaving the valve) you can then add another valve or 10 for whatever you want to control. They make electric valves and switches that go on the FEL joystick for and easy grapple/snow plow/etc control. You could also add stacked valves for something off the 3 point.
Supply House is fine- the stuff seems to work fine. I’ve also ordered from Home | Trausch Dynamics
Their stuff is nice.
RNeumann thanks for your input.
I understand about third functions. I just figured that if I needed to replace the whole assembly I might as well put a 3 spool in and have it all together....the cost of an add-on third function kit is more than a new 3 spool valve. I had not seen that specific video tho ... thanks.
   / Need Advice on FEL Valve Replacement #6
Your proposed plan would work - it’s just abnormal to have separate levers for lift and curl of the FEL. Maybe they make a joystick style stacking valve- I’ve never seen one though.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
Unused 2025 CFG XZ20R Mini Excavator (A50322)
Unused 2025 CFG...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
