Need advice on adjusting my 273 HN baler
   / Need advice on adjusting my 273 HN baler #11
Make sure the knotter brake is holding the knotter in home position until the knotter trips
If the home position is set correctly the weight of the needles and carriage will hold the knotters in place against the trip pawl. This is an often overlooked adjustment and accompanying fact. If knotted home is correct, brake tension is far less important than when it is incorrect.
   / Need advice on adjusting my 273 HN baler #12
Had the same type of problem with a JD baler. It seems the linkage for the plunger stop was worn to the point that on a side hill, it would swing in enough to stop the plunger. The quick fix was to add a spring to the linkage to take out the slop.
2016 ELDORADO NATIONAL EZ-RIDER CNG BUS (A58018)
2016 ELDORADO...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
Informational Lot - Shipping (A56435)
Informational Lot...
APPROX. 100 GALLON TOTE W/ ANTIFREEZE (A52708)
APPROX. 100 GALLON...
